Need ideas on what to check to fix backfiring.
Subscribe
Apr 17, 2002 | 06:48 AM
I took my car to emissions to get it checked out. It passed but on the way home it started backfiring. I checked the wires/cap/rotor. All seem fine. It runs fine if I disconnect the brown ground wire on the passenger side. I replaced the ignition module and it didn't help. What else should I check? It has 125 ok it. I was thinking maybe there's a bad ground or something.
Reply 0
Apr 17, 2002 | 03:07 PM
exhaust leak?
Reply 0
Apr 17, 2002 | 04:28 PM
Yes, but it runs FINE when I disconnect the brown ground wire.
Reply 0
Sounds like someone ****ed with the Timing.
Reply 0
Apr 17, 2002 | 04:48 PM
I have an Ed Wright chip, do they eventually go blank over time?
Reply 0
Apr 17, 2002 | 04:56 PM
No, I mostly meant Base timing.
did they Just check it, or did they work on it too ?
If they just tested it, its sorta hard to imagine them ****ing something up other than maybe crossing a plug wire or causing one to short.
Reply 0
Apr 17, 2002 | 05:19 PM
They changed the battery but that's all. It seemed like it took the dude forever to change the battery though, I don't think he knew what the hell he was doing.
Reply 0
Apr 18, 2002 | 01:21 PM
Fixed it, was the timing. I triple checked it now it works great.
Reply 0
Apr 19, 2002 | 09:00 AM
Damn, it's doing it again. It's giving a code 42 also
Reply 0
Apr 20, 2002 | 04:12 PM
Found the real problem, the distributor shaft was separated from the reluctor, replaced distributor and it runs great.
Reply 0
Subscribe
