cam question, LT1 vs. stock 89 Iroc
Old Apr 17, 2002 | 03:36 PM
89Irocker's Avatar
I just got an LT1 cam from a 95 Z28 and want to replace the stock cam in my 89 Iroc, will I see a big difference? Is it even worth the trouble to swap them? Thanks for any advise.
Old Apr 17, 2002 | 04:40 PM
Bort62's Avatar
no.
Old Apr 18, 2002 | 03:22 AM
89Irocker's Avatar
Anyone else have an opinion? cause I would like to go ahead and do the swap, but if it isn't going to add jack **** for power then maybe I shouldn't. would I at least see, say 20hp?
Old Apr 18, 2002 | 06:24 AM
ImportsRsloths's Avatar
I doubt it because its a 305............ POST THE SPECS OF YOUR CAM AND THE LT1 cam and it will help A LOT!!!!
Old Apr 18, 2002 | 10:06 AM
camaro6spd's Avatar
CHILL OUT...if he as a G92 5 speed then it would add alittle, not too much, i am thinking 10 or so.....but if it is non G92, i am thinking like 35.
Old Apr 18, 2002 | 10:09 AM
Beefy89's Avatar
Sure it'll make a difference!
I put a 96 LT1 cam in my L98 with a set of 1.6 roller tips,and I'm sure I picked up 20hp.
I'm not sure of the specs on on the 95 LT1 cam that you have,but the 96 that I put in are .447/.459"lift,205/207 deg duration @.050 with a 117 LSA..........
Your 89 cam should be .415/.430"lift,207/213 deg duration@.050 with a 115 LSA.
As far as being"worth it",that all depends on what you want the car to do.My car is driven 35/40 miles per day through the warm months,with a couple of trips to the track in the summer....
Old Apr 18, 2002 | 01:31 PM
89Irocker's Avatar
I know its not a G92, and I'm not sure what the specs are on my current cam. Thanks for the replys though. I think I am going to go for it this summer when I have some time and a little more $. The cam was really cheap and in great shape so why not? even if it only adds 15-20hp I think it could be worth it.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
