LS1 intake
Old Apr 18, 2002 | 01:13 PM
Swapmaster's Avatar
LS1 intake
What's the difference between a Camaro and a Vette LS1 intake?
I just bought a 2000 Camaro intake for $80 complete with
throttle body, injectors and rail.
Did I do good or would a Vette intake be better?
Don't know anything about the LS1.
Also what needs to be done to use it on a 1988 350 engine?
Old Apr 18, 2002 | 01:33 PM
ImportsRsloths's Avatar
LOL i really hope you didnt buy an LS1 intake........ hopefully its an LT1 intake
Old Apr 18, 2002 | 01:38 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I think the newer ones all use LS6 intakes, but I'm not sure. For what it would take to fit an LS1 intake on a Gen 1 you might as well build a sheetmetal intake or something. Gen3's are pretty much completly different than older sbc's. The spacing for the intake ports are different, along with probably about everything else.
Old Apr 18, 2002 | 01:50 PM
Swapmaster's Avatar
Ok, I just called and canceled it, thanks for the info.
Old Apr 18, 2002 | 02:05 PM
Biochem's Avatar
Car: 2002 SOM z28
FWIW, around '01 they started putting the LS6 intake on the Camaro. LS6 block too, as if it matters The LS1 heads are like 19 degrees vs. the SBC heads which are 23 degrees I think, so they would not fit a small block.
Old Apr 18, 2002 | 03:04 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Forget about the angle... the LS1 uses an entirely different port location. On the SBC, the intake ports are paired next to each other... on the LS motors the intake and exhaust are staggered.
Old Apr 18, 2002 | 03:07 PM
Guest
Guest
Posts: n/a
LS1 heads are like 14 degrees.
What needs to be done to use it on an 88 350... Ummmmmmm... Well considering nobody has done it yet and its not really a feasible idea if you have your head screwed on straight (I dont) its impossible. At a minimum, you would need the heads too, which of course wont bolt up to the SBC (something about the head bolts being in entirely different locations).
Old Apr 18, 2002 | 03:55 PM
Swapmaster's Avatar
Thanks, I canceled the order. Nice try though hu? I don't know
anything about those engines, that's why I asked, I knew that
someone would set me right.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Sep 19, 2015 08:13 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
