Vacuum line with ?check valve?
Old Apr 21, 2002 | 12:32 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The batteries for my dig camera are dead so I'll have to explain this.
There are some vacuum lines coming out of the pass side rear plenum by the MAP sensor. The rear line goes to the fpr. The front line goes to what looks like a check valve then t's off to the cruise control and the other goes into a mess of wiring.
My question is this.....Is it a check valve and if so, which line is supposed to let vacuum flow only one way? Seems to me like it's acting as only a "T". No blockages any way.
Old Apr 21, 2002 | 06:30 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
That should go to the vacuum resevoir for the AC system.
Old Apr 22, 2002 | 11:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Since I removed my AC would that then cause a problem? Should I remove that vacuum line going to the ac and plug up the port on the check type valve?
Old Apr 22, 2002 | 02:21 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Why does the AC system need a vacuum resevoir??
Old Apr 22, 2002 | 03:23 PM
Ricktpi's Avatar
To store enough vacuum to operate the AC/heater doors in the dash. It also stores vacuum for the cruise control servo. If these where hooked up directly, with no resevoir there would not be enough volume to make them work properly.
Old Apr 22, 2002 | 03:46 PM
Car: 1991 Firebird
Engine: 427 LSX
Ohhhh, you didn't really mean for the AC system. IMO, the engine is a pretty large vaccum resevoir itself. I removed my vac resevoir. My vents are a bit slow to change positions though.
Old Apr 22, 2002 | 05:49 PM
Ricktpi's Avatar
Yes I did mean the AC system. GM has used that basic design since the early 70's.
Old Apr 23, 2002 | 08:27 AM
Car: 1991 Firebird
Engine: 427 LSX
So cars with no air conditioning do not have this resevoir????
Old Apr 23, 2002 | 08:35 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
The AC setup in my Cutlass used the vacuum operated doors and everything. The AC delete box in it now just uses cable operated doors, which (I think) is much simpler.
Old Apr 23, 2002 | 10:07 AM
Ricktpi's Avatar
Yes, Camaros without factory AC had a cable operated system, no vacuum harness.
Old Apr 23, 2002 | 10:20 AM
Car: 1991 Firebird
Engine: 427 LSX
so since, i removed my canister, is my AC door or something not opening or closing correctly??
Old Apr 23, 2002 | 10:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Cool so far.
But is it a check valve or just some fancy looking 'T'?
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
