cowl induction pics on a monte carlo
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
I had a few requests of how I had my set up for my cowl induction so Im going to just put them onhere incase anyone else wanted to see, I didnt get my gaskets in friday (thanks to UPS) so I just placed the intake where its supposed to go, but Im sure you guys will get the idea. I took the front piece (directly off the throttle body) from the paxton I have, but Im working on making one out of fiberglass, and when I get it complete Ill overlay the whole thing with carbon fiber for a custom cool look, the air cleaner is just a piece of plexy glass that I took a propane torch to and heated gradually and rolled the corners arount a piece of the 3" aluminized exhaust pipe I am using in a few places.
not sure how to do more than one pic so here it is from the side
Car: `86 SS / `87 SS
I think the 97 or so SS hood scoop stuff would be nice w/ a 4th gen camaro SS scoop molded into a Monte hood.
If you have a Paxton, why are you doing a hood induction scoop?
"If you have a Paxton, why are you doing a hood induction scoop? "
I had it feed off the cowl to the paxton, made a cleaner compartment when it worked but didnt like the paxton so just used what I had to bypass it all. Thought about the camaro SS set up but its reversed (sucks the air off the front of the hood) and by time I turned everything around to pull off the back I dont think that the bend would have cleared the AC pump, Besides with the KNN filter right now I have about $100 into it(that is if I would have had to pay for the filter, got a good deal on it!!)
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm thinking you have quite a bit of vacume leak there judging by the gap where your runners and plannum meet
Serriously, it looks good. Did you notice any difference?
Rob
Rob
hahaha yeah vacuum leaks-R-us would be this situation, that problem will hopefully be remidied this weekend since I got my gaskets in, as far as any gains, its hard to tell I did that when I rebuilt the engine last year it was an all in one thing it seems no one ever makes one modification at a time to try to see what differences it makes, I know I dont, I did it more just to make the hood functional I was using it to eliminate the possibility of cooling problems with getting air forced the wrong way, seems to have helped in that dept, but could have also helped since I was getting cold air instead of semi cold air out of the engine compartment, I had a tube that went behind the headlights, but it wasnt sealed off so there isnt any telling how much cold air I was actually getting.
thought you might like that bob, got the gaskets monday and hopefully will have it all together friday night!
monte-ss ,...
not to be rude or anything ..but from those pics i dont see a paxton...all i see is the paxton pipe...but i think the S/c must be there ....somwhere got any more pics man...
nice cowl install though
first of all thats 3 questions! haha
had the MAF before the paxton there wasnt enough room for it after it, did have an AFPR hadnt gotten into the chip at the time, just starting on doing that here shortly
Hotrodboba400
Dec 10, 2019 07:07 PM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
