My pcv keeps shooting out
Old Apr 23, 2002 | 08:54 PM
89 Iroc's Avatar
At WOT my filtered air thing kept shooting out of the valve cover and smoke would shoot out everywhere but I put a new grommet in and it stopped. Now the pcv valve keeps popping out but the grommet on that side is new too. I dont know what is going on.
Old Apr 23, 2002 | 09:13 PM
Chet's Avatar
Car: GTA
um is the valve stuck closed. If you take it out and shake it up and down it should rattle.
Old Apr 23, 2002 | 09:17 PM
89 Iroc's Avatar
No the pcv valve is fine its brand new.
Old Apr 23, 2002 | 09:26 PM
KS91Z28's Avatar
Sounds like you're getting a lot of blow-by. How many miles do you have on the engine?
Old Apr 23, 2002 | 09:27 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ummm.... that's not right. Let me know if you figure out what the problem is.
Old Apr 23, 2002 | 09:28 PM
89 Iroc's Avatar
87,000
Old Apr 23, 2002 | 09:29 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Sounds like to much crankcase pressure, which can be caused by a vacuum leak or worse your rings aren't sealing. Have you done any mods recently?
Sparks a flyin'
Jeez, are you guys on broadband or dsl? I type the above and send and you've already posted 3 more times
Old Apr 23, 2002 | 09:32 PM
89 Iroc's Avatar
My car is completely stock except for a dynomax exhaust. It could have a vacuum leak it kinda sound like theres a whistle coming from somewhere when I'm driving
Old Apr 23, 2002 | 09:35 PM
89 Iroc's Avatar
If its a vacuum leak I dont know where to even look. When I got the car the metal tube coming off the AIR pump was loose and the car ran like crap but I fixed that last year. If it came loose again could that be causing it?
Old Apr 23, 2002 | 11:59 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The vacuum hose that normally goes bad the fastest is the one line running being the distributor to the cruse control, charcoal canister, and vacuum canister (don’t know what it is called).
Old Apr 24, 2002 | 01:48 AM
Bort62's Avatar
Im not really sure how a Vaccum leak could cause excessive crankcase pressure, except maybe if the leak prevented the PCV from getting sufficent vaccum and ventilating hte crankcase.
how fast does your oil get dirty ?
Old Apr 24, 2002 | 01:58 AM
89 Iroc's Avatar
I dont know. I only need this thing to run right for like another month and a half to 2 months until I get a new motor. But it is just pissing me off that it keeps popping out? My stepdad mentioned something about the passages in the heads or the block could be clogged with crap could that be a possability?
Old Apr 24, 2002 | 02:13 AM
Bort62's Avatar
Yeah. Ive had this mentioned to me with similar problems in the past. Im not entire sure how that works... but aparantly your stepdad isnt Completely out to lunch
We had this problem a year or so ago with my friends Vette. It kept blowing out oilpan gaskets, VC gaskets, VC breathers, everything.
We couldnt figure out what the hell it was, But eventually we figured out it was worn rings.
The motor will probrably run for your 1-2 months with the bad rings, just take it easy, avoid overheating and high RPM.
Another way to Confrim this is to Change your oil, Then watch how fast the oil gets dirty.
Blowby gases impregnating in the oil will turn it black VERY fast.
A well Running engine should maintain clean oil thourghout the entire oil change interval
Old Apr 24, 2002 | 02:20 AM
89 Iroc's Avatar
Actually now that I think of it it makes sense when he said it. He said it 2 days ago when breather side was popping out so I guess he meant the driver side passages could be clogged causing the passenger side breather to pop out. He doesnt even know the pcv valve pops out.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
NZKnight
Oct 15, 2015 02:47 PM
meeklay812
Oct 1, 2015 03:46 PM
