TPI 1/8th mile times
Old Apr 24, 2002 | 04:45 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Well I've been to the local eight mile now twice. Both times I've been running like 2.35 60' times on average. Its pretty pathetic... but I can't launch this 6-spd for **** at the track. I'm running 9.5's@75mph with the 2.35's. I'm hoping for 9.1's or better with Nittos. What do you guys think??? Moda re on my page... basically: LCA, APHR, AFPR, 255lph, K&N, TES headers, no cat, 3"cutout, flowmaster, T56 & 3.42's, coil, and MSD 6A too name a few. Problem is... this motor has 156k miles on it. I don't think a 9.1 or 14.0 would be bad for this motor. Gotta get that hotcammed 350 done soon!
*What are everyone else's TPI eight times?
Old Apr 24, 2002 | 07:40 PM
88ROC1LE's Avatar
see the sig 230,000 miles on the motor
Old Apr 25, 2002 | 11:02 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
dont know yet, still waiting to take my car to the track, i've been beating LT1's so i'm hopeing for some 14.0's, and low 9's in the 1/8th, i saw a couple 305's like mine with a couple less things than i have and they were running 8.8's !! believe me my fingers are crossed and i'm gonna be a happy man if i see those kinda times.. one way or anouther i'm going to get my car in the 8's, either n/a or with NOS, i dont care lol.. - mike
Old Apr 25, 2002 | 12:50 PM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
When I get good traction Im in the 8.50s in the 1/8th at 76-77 MPH give or take with just boltons, mild tranny work and sticky tires....
Old Apr 25, 2002 | 05:55 PM
JAY87GTA's Avatar
It's in my sig. On a 2.08 60' time. I can get pretty consistent 2.11 60' and I have no mods other than energy bushings in the LCA's. Hoping for sub 2.0 after I get my converter in.
Old Apr 25, 2002 | 06:51 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
best slip:
0.544 - rt (yes i can be deadly when i'm on)
2.063 - 60'
5.960 - 330'
9.193 - 1/8
75.67 -- mph
12.007 - 1000'
14.380 - 1/4
95.24 -- mph
And not counting my first run my rts averaged 0.600, and all my 60's were 2.0s. I was the only person hooking not on full slicks. Even typical low 13 second cars were seeing taillights till the 1000' mark between their .9 rts and lack of traction. It was a good night
If all goes right i'll be getting slips with the vigilante tomorrow night. Should be interesting to see what i can get with a stock 305 and a 3k stall converter One things for sure, it's jacked up like a mother and ready to go kill some rustnags!!!
Combo is:
- 305 TPI / 700r4 / 3.23
- Ported plenum
- SLP 1 5/8 headers, coated, dual cats
- Flowmaster cat back w/ improved Y, single outlet 3" 30 series.
- Custom PROM (by me)
- Holley AFPR
- 22lb injectors, flowmatched
- Relocated LT1 MAT, Free Mods
- Accel wires / cap / rotor / shorty plugs - KN filters
- 1LE / JG1 aluminum shaft
- Mobil 1 in the crankcase and rear
- Dunlop SP 5000 tires - 245/50 - 255/50
Old Apr 25, 2002 | 10:35 PM
Adam62083's Avatar
Bone stock I was hitting 9.35's
Now I am hitting 8.9's with full street trim.
Old Apr 25, 2002 | 11:45 PM
88 IROC BOB's Avatar
8.9's between 77-78 mph.
Bob
Old Apr 26, 2002 | 08:49 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re
Gees. I'm slow! Guess I need to set my fuel press, change my bad EGR, and get some tires or figure out how to launch this 6-spd and 3.42's! Later guy. Great times!
Old Apr 26, 2002 | 09:03 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
8.423 @ 82.75mph
Old Apr 26, 2002 | 09:10 AM
CainRocZ's Avatar
1988 IROC-Z 350 TPI... flowmaster muffler, gutted airboxes, jet air foil...... 9.28 @ 75 mph. 2.01 60 ft.
Old Apr 26, 2002 | 11:58 PM
Ed Maher's Avatar
Car: 04 GTO
Update, new times with the vigilante tonight:
1.875 - 60'
5.689 - 330'
8.924 - 1/8
75.64 - mph
11.734 -1000'
14.106 - 1/4
95.37 - mph
Yes, the only change from the previous set of runs was the vigilante converter. She definitely has a 14.0 / 13.999 in her as she sits if i could have had the time to sort out shift points as well as experiment with TCC lock-up . As it was, a lot of bad stuff was going down and i only got 2 runs in. And yes the 60' is real, my first run was a 1.91.
Important to note that i ran that 1.8 60' on REAL street tires, and with a completely stock suspension. Anything is possible if you know how to walk it off the line...
Here's an action shot off the line http://home1.gte.net/res0t8sj/vert/extension.jpg
Old Apr 27, 2002 | 02:08 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I ought to give you my GTA and see what happens . But I think you will find it much more challenging to walk it when you add some more ponies. Very nice work Ed .
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
