Low ohm reading on injectors
Old Apr 25, 2002 | 08:27 PM
formcam's Avatar
I have about 4 injectors on my 89 formula that are reading at 5 to 2 ohms. One at 16ohms and the rest at 12-11 ohms. What would cause an injector to lose its ohms? Is the 16 ohm at proper spec?
Old Apr 25, 2002 | 08:29 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Im not sure the proper ohm rating for injectors, but I do know that they should all be within 2 ohm's of eachother.
It sounds like its time for some new injectors for you, or have them flowed and balanced if thats convenient for ya!
Old Apr 25, 2002 | 09:06 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
We run saturated style injectors; I think 15Ohms is about right.
Sometimes the insulationi comes off the windings causing them to short together (one reason to NOT use injector cleaner on our injecotrs).
In any case it's time to replace some or all.
Old Apr 25, 2002 | 09:27 PM
Swapmaster's Avatar
New injectors will read 15 to 16 ohms. An injector below 12.5
ohms should be discarded as bad.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
