Pics of SLP runners on engine
Old Apr 27, 2002 | 05:11 PM
johndo1707's Avatar
I got these runners for $150 and sold my old ones for $100, not bad for $50 huh.....
Old Apr 27, 2002 | 05:14 PM
johndo1707's Avatar
top view
Old Apr 27, 2002 | 06:39 PM
87_Camaro's Avatar
looks nice, and if i may ask, what kind of intake is that? "duh it's a K&N" but how much of a gain do you get of that compared to gutted dual snorkle??
Old Apr 27, 2002 | 10:40 PM
TransAm87's Avatar
wow hot set up johndo
Wow,,thats is awesome..hahha..that is the stock air intake on a trans-am compared to the snokle on the camaros...make a homemade cold air intake.....to get the best performance...
Aj
Old Apr 28, 2002 | 01:21 AM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
where did you get those for $150? and do you feel a difference?
Old Apr 28, 2002 | 01:28 AM
johndo1707's Avatar
that's the stock air intake system on my car. only the camaro's have the dual snorkel. i'm guessing the one on the firebird's like this one are a little less restrictive because it only has one air filter instead of two but i'm not sure. build you own kit with an open k&n or somethign or if you wanna spend some money, go with an slp cold air intake system for around $150. good luck!
jeff
Old Apr 28, 2002 | 03:40 AM
92TPIZ28's Avatar
Engine: 355
i was wondering if the slp runners made a difference in power because i'm debating if i should get some.
Old Apr 28, 2002 | 09:15 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
once I get my stealth ram delivered and installed mine will be for sale, dont know what Im asking yet though.
Old Apr 28, 2002 | 02:11 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Did the runners make your car faster???
Old Apr 28, 2002 | 04:57 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Looks nice.. I always liked the SLP Runners look.
This is forsale in the Classifieds!!
Chris
tpi383@svol.net
Old Apr 28, 2002 | 06:01 PM
86FyrBrd's Avatar
They give you a lil more top end, it doesnt drop off as bad towards the top of your revs with these runners
Old Apr 28, 2002 | 07:36 PM
johndo1707's Avatar
well on the performance side i think they work great! i definitely noticed the top end increase and the low end seems to be better too. i heard that they take away from the low end but that doesnt seem like the case at all with mine. i like them a lot and i think they will work great on my new motor once i get it going. as far as the porting i did, i ported a lot behind the throttle body because that area seems to be restricted a lot and i had to port the runner holes out because my runners are siamesed now and other porting was done inside the whole plenum. probably picked up a few more horsepower from that job, seems to run great now! :lala:
Old Apr 28, 2002 | 09:03 PM
86FyrBrd's Avatar
TPI383, did your throttle body spacer add anything?
Old Apr 28, 2002 | 09:42 PM
bigals87z28's Avatar
Car: Check The Sig
86FyrBrd thats a nitrous plate... you can see the injector for the nitrous on the left side
Old Apr 28, 2002 | 09:46 PM
87_Camaro's Avatar
[i]Originally posted by 86FyrBrd Originally posted by
oooohhh just a little bit
Old Apr 28, 2002 | 09:51 PM
86FyrBrd's Avatar
now that I look at the side if it I just looked at the top and figured it was a spacer.
yeah so I guess it does add alot
Car: Check The Sig
AHAHAHAHAH that was funny !!!
Old Apr 28, 2002 | 10:37 PM
johndo1707's Avatar
does anyone know if a tb spacer would even do anything on a tpi setup? i don't really think it would do much beside adding a little more velocity to the airflow, but the spacer would have to be pretty big i dont know......
Old Apr 28, 2002 | 10:51 PM
86FyrBrd's Avatar
does anyone even make one? I just saw it and thought thats what it is, I have never seen one for TPI before.
Old Apr 28, 2002 | 10:58 PM
Car: Check The Sig
i think that TB spacers are more for like TBI like a carb spacer.... i dunno i have seen it for stangs..... but i guess you will get the same effect from an air foil as from a tb spacer... but that nitrous plate look nice...i saw it in a 305 camaro over the weekend at a car show... if i didnt see it there i would of said the same thing you did....thats y i love this place!!! aight peace im gettin some sleep
Old Apr 29, 2002 | 07:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
back to the runner flow conversation...
The air path is like a hose. If you've got a 5/8" garden hose, and replace a section of it with 1.5" hose, the total flow is still going to suck. You have to replace the whole thing with 1.5" hose to get the most benefit. My point? Just replacing the runners won't do squat. If you don't port the plenum to match, you'll get zero gains. If you port the plenum, you'll still only get minimal gains. You'll realize their potential when you replace the baseplate and the exhaust manifolds.
Old Apr 29, 2002 | 12:27 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Question
Which runners are larger?
SLP runners or the Runners that come with the Acell super ram kit?
Thanks. I am just wondering.:hail: :hail: :hail:
Old Apr 29, 2002 | 02:12 PM
Jim85IROC's Avatar
super ram runners are totally different. They're 1/2 the length. Not at all compatible with a stock TPI plenum.
I believe that the accel long tubes flow more air out of the box than the SLP runners, but I think the SLP runners may have more meat for additional porting.
Old Apr 29, 2002 | 02:15 PM
johndo1707's Avatar
i think i heard that the slp's are the largest, but maybe only because you can port them, i siamesed mine and ported the plenum.
Old Apr 29, 2002 | 02:16 PM
Trux's Avatar
Transmission: t-56
doh
sorry. I was not thinking when I posted that.
tazs2000
Jul 15, 2017 08:44 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Linson
Aug 21, 2015 02:12 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
