How is idle w/ LT4 Hotcam? Any Lope?
Old Apr 28, 2002 | 03:50 PM
Mike86Z28's Avatar
Car: 98 Z28
Just wondering how the idle is w/ an LT4 Hotcam. I would think it wouldn't really sound much over stock but I could be wrong. I want a cam that has a little lope to it when I do the AFR/Superram base/Etc. swap and based on what everybody tells me here the LT4 Hotcam is the way to go. So how is the idle?
Old Apr 28, 2002 | 04:10 PM
388iroc's Avatar
yup...
well ive never actually heard one but a while ago there was a guy talking about another guys car in the club who had the hot cam and he said that it gets lumpier every time he heard it. i think that he was exadurating a little but it should have a little lope to it. What youre looking for to see if its gonna have that lope sound is the lobe seperation, it should be 108 110 112 something like that, the smaller the number the more "lope". hope that helped.
Old Apr 28, 2002 | 04:23 PM
Mike86Z28's Avatar
Car: 98 Z28
Thanks man...that's what I needed to know.....
Old Apr 28, 2002 | 04:57 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I have a good soundclip of the cam. If you want it just e-mail me .
Old Apr 28, 2002 | 07:57 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Here is a clip of mine. (kind of distorted, but eh.......)
Clip of Hot Cam at idle (from about 10 feet away)
Clip of Hot Cam at idle with rev (mic too close - bit distorted)
LT4 Hot Cam specs:
Duration @ .050 lift: 218* Intake / 228* Exhaust, .525"/.525" valve lift with 1.6:1 rockers, 112* LSA.
Old Apr 28, 2002 | 08:30 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Lope has little to do with LSA, it has everything to do with valve overlap. A cam with a smaller LSA will have more valve overlap than the same cam with a wider LSA. But it's the overlap that causes the lope, not the LSA.
Old Apr 28, 2002 | 09:31 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Mine definitely has a lope to it, but its not annoying or too much.
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
mine sounds like matt's, it might be a little mellower if i had a cat on the exhaust. i just got the car running decent and so far i'm quite pleased with the cam. the lope's there but it's not really pronounced. it'll let you idle 600-700 easy
MustangBeater20
Oct 29, 2022 09:20 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
steve88iroc
Jul 19, 2001 04:13 PM
Jas89TTA
Apr 28, 2001 11:40 AM
branz28
Apr 11, 2001 04:25 PM
