Just ohmed my injectors, is this a good sign?
Old Apr 30, 2002 | 11:52 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I have tested all of them and the readings i got were from the
- lowest being 17.2 ohm
- highest being 17.4 ohm.
That this mean that they are all ok?
Old Apr 30, 2002 | 11:59 PM
GhoSSt's Avatar
Re: Just ohmed my injectors, is this a good sign?
Yep.
Old May 1, 2002 | 08:40 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Ideally you should check them both cold and hot, sometimes the coils in them don't show problems until they are hot.
Also, just because they ohm out does not mean they are clean and match in flow, are you chasing a certain problem, or just a routine check-up?
Old May 1, 2002 | 11:47 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I am just checking from curiousity. You can say as a part of spring tuneup.
I will have to check them again when the engine is hot. I checked them when the engine was warm but not hot.
Thanks for replies guys.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
