ok heres the car facts.. pretty much stock 92 L98 with AFPR, headers and full exhaust. thats about it.
symptoms - whenever the car is cool (doesnt happenw hen its warmed up) and i pull onto the highway and get on it a little bit (between 3/4 and full throttle) the car actually starts to intermittently shut off. all guages die for a split second and everything catches back up and then dies again, fine again, dies again...
anyways.. any ideas on what it could be?
mike
mike
not sure about your problem, but do you like your bbk afpr. I just bought one, but havent installed it. Did you have enough room under the plenum. Does it work good. What psi did you set it at?
Check your grounds and all your power suplies...even take a peek at the fusible links near the starter , sounds like u have something not quite getting contacy when cold but doing ok when hot
i started it up this morning and got on it as quick as i could just to see if it would do it, no problems. keep the suggestions coming though cuz it could show up at any time....
Go through your grounds with a dfine toothed Comb.
I lost a fusbile link and i lost every non-essential electrical peice of EQ on the car, including all the lights.
I think the only thing still working was the ignition.
had something real close happen to my last car...Check all vaccume hoses. That was my insta fix one was broke right off...fixed for like 1 dollar then just like new.
John D.
John D.
Clarify, are you loosing electrical For that split second ?
A Faluty Vacum Line won't have anything to do with a electrical blip.
yes it loses everything.. like basically the car is shutting off. when its done it i've noticed the voltmeter going to nothing and the air fuel guage going off and then falling to full lean real quick....
