Anyone with custom air intakes please come inside!
Old May 1, 2002 | 12:27 PM
Nasty_Bird_'90's Avatar
im getting ready to drop in aTPI L98 into my bird and want to do a custom intake of some sort. what have you guys done? id like to see some pics if possible. from what ive seen, i can either put a "cone" style filter right in front of the throttle body, or have a piece of tubing bent and end in where the battery sits. any help would be appreciated. thanx
Old May 1, 2002 | 01:47 PM
TBurke's Avatar
check out the Thunderracing website. I think they sell the SLP cold air kit for those cars.
Old May 1, 2002 | 02:04 PM
mtccl's Avatar
Check out my webpage. Full instructions for mine. I have changed mine to a K&N cone filter. Here is the filter link. Just find the biggest one that fits and slap it in there.
http://www.knfilters.com/universal/univrndtap.htm
Attached Thumbnails Anyone with custom air intakes please come inside!-intake.jpg
Old May 1, 2002 | 03:53 PM
Ron Mullins's Avatar
Here's what I made.
http://www.geocities.com/91formula/ramair.html
Old May 1, 2002 | 07:23 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
HERE YOU ARE
COST ME $50 INCLUDING THE K&N 9"CONE FILTER
Attached Thumbnails Anyone with custom air intakes please come inside!-dsc00002.jpg
Old May 1, 2002 | 07:30 PM
jerflash's Avatar
LIST OF PARTS I USED:
4"TO3" FLEXABLE PVC ADAPTER, 3" 90% ELBOW FLEXABLE PVC HOSE, 3"TO3" FLEXABLE PVC HOSE, REGULAR PVC 45% ELBOW, 1 FT SECTION OF REGULAR PVC(CUT TO CONECT EVERYTHING,PVC GLUE, AND 9" CONE K&N
THAT ALL IT IS SIMPLE
I DID HAVE TO MOVE MY CHARCOAL CANISTER OVER A BIT
Old May 1, 2002 | 07:32 PM
jerflash's Avatar
OH AND I FORGOT
THE 9"CONE MUST BE A 3.5" INLET
Old May 1, 2002 | 08:00 PM
Bort62's Avatar
There, Jerflash gives you a list of everything you need to build a functional if not beautiful CAI.
Now go forth and Do.
Old May 2, 2002 | 03:07 AM
Kandied91z's Avatar
i'm sure you are all sick of seeing mine, but.....o'well!
Attached Thumbnails Anyone with custom air intakes please come inside!-engine-pic-2.jpg
Old May 2, 2002 | 07:41 AM
Steve10's Avatar
Take the time to do it clean with stainless elbows and pipe. I'm about to do the MAF to MAP ECM swap, so I will get rid of the MAF and have a continous piece of stainless in there. You can make it look good with the MAF though.
Attached Thumbnails Anyone with custom air intakes please come inside!-engine.jpg
Old May 2, 2002 | 10:18 AM
BlazinOR's Avatar
Where did you get the stainless parts? Looking good...............
Old May 2, 2002 | 10:33 AM
Steve10's Avatar
I ordered the elbows from a co. in Houston called PAC Stainless, and I found the pipe in the maintenance shop at work. I brought the elbows in to work and had one of the maintenance guys weld it up. Took him less than 30 min. I used 3" red silicone hose pieces on each side of the MAF. Those 3" to 3" sewer connectors are very bulky. The turbo guys make their connections with that sorrt of hose all the time.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
