egr block off. . .
Old May 8, 2002 | 10:25 PM
FstBrd6point3's Avatar
egr block off. . .
does anyone make a plate? or is it something I am going to have to get custom fabricated??
Old May 8, 2002 | 10:53 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I know TPIS sells them, most likely any manufacture though of an aftermarket base should be able to supply you with one.
Old May 9, 2002 | 01:05 PM
tpi_roc's Avatar
Talk to john millican
I know he distributes his LT1 intakes with them, but i dont know if he makes them or buys them.
either way his prices are fair.
Old May 12, 2002 | 01:00 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i have a 89 formula and everything is still in tact under the hood, what will pulling the EGR valve and blocking the hole do?
Old May 16, 2002 | 04:21 PM
tpi_roc's Avatar
Possibly cause detonation
your S.E.S light will stay on too
Old May 16, 2002 | 09:27 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Will blocking the egr really cause detonation?If so are there any ways to correct that afterwards?
Old May 16, 2002 | 10:33 PM
rockind78's Avatar
Or you could just leave the EGR on and be a little more environmentally friendly . The EGR costs a small amount of power at cruise or part throttle, but is turned OFF at WOT, so this won't affect your ET.
Old May 16, 2002 | 11:05 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I can confirm that disabling the EGR does cause detonation (at least in my case.) I average about 4 degrees of knock retard on acceleration... I'm in the process of editing my spark tables to get rid of this.
And I'd like to be more environmentally friendly... but my EGR valve was stuck open (nothing 125 PSI out of an air gun couldn't fix) and I can't justify the cost of the replacement valve. Besides, I don't think my future intake (Stealth Ram) has provisions for it in the first place.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
camarohelp
Sep 22, 2015 03:19 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
