need help, opinions please, comp cams?
Old May 12, 2002 | 06:47 PM
Don_89Iroc's Avatar
I have decided to go with a milder cam in my car, im leaning toward the comp cams in Summit its the high energy/ magnum cams and im thinking the 212* duration and .440 lift or should i go a hair bigger and get the 218 duration and .454 lift??? i dont want to run this cam with expensive heads either im looking for a set of L98 vette heads if also looking at roller rocker arms with this cam what ratio rocker arms would you recomend? 1.5 or 1.6?? and what RR are good there a S**T load of them in Summit
Thanks for your help -Don
Old May 13, 2002 | 04:42 PM
tpi_roc's Avatar
If you're trying to go with a milder cam why buy a weak one then put 1.6's on it.
run some 1.5s
Old May 13, 2002 | 07:33 PM
Don_89Iroc's Avatar
thanks for the reply, any one else?? what about a comp cam 260 series?? please i really want your opinion's before i buy
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
