Need new heads - Trick Flow's any good?
Old May 14, 2002 | 05:58 AM
Forgiven's Avatar
I found this part number - TFS-30400005 for $969.95 at Summit (pair complete).
It looks like these are a 100% bolt on with only gaskets required to make the swap. Is this all that's needed?
The 64 cc chamber would drop cr down a bit though, any idea how much (stock L98 bottom end)?
The other option that I was considering was the Vortec heads with the Scroggin Dickey Vortec base but that would cost as much or more than these heads AND I do not like press in rocker studs.
I appreciate any input that you have.
Thanks,
Ernie
Old May 14, 2002 | 09:22 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I personally don't like those heads with tpi, but many will disagree.
Old May 14, 2002 | 12:11 PM
Morley's Avatar
Re: Need new heads - Trick Flow's any good?
Thanks,
Ernie
You'll need special length pushrods (possibly) with these heads, so get a pushrod length checker, also Trickflow includes a sheet with them that lists a bunch of rocker arms and what length pushrod to use for them, but its best to check it yourself.
I have a pair of these heads on my '85 TPI (new 350 engine) and they seem to work great, I'm still getting the first 500 miles on the engine for break in.
~M~
Old May 14, 2002 | 12:56 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I don't want to sound like a curmudgeon here...but use the "search" function. This has been covered...
They are a good head, but it depends on what your combo is, what kind of cam you want to run, HP goals, etc...
Old May 14, 2002 | 01:18 PM
Forgiven's Avatar
Thanks for the info guys. My immediate need is new heads and I do need heads that will work well later with a mild cam, headers, better intake, converter, etc.
And most importantly...COST.
These look good from price only because they are compatible with the stock TPI and they flow pretty good. The VORTEC swap is about the same money so I think I like these better.
Just wanted some opinions.
Much Appreciated.
Ernie
Old May 14, 2002 | 01:21 PM
Engine: LS3
Transmission: 6L80E
If cost is the key factor...then you wouldn't be looking at aluminum, right?
The Trick Flow budget heads sound fine for your combo...
Old May 14, 2002 | 01:28 PM
Forgiven's Avatar
Good catch!
Performance is more important, cost is secondary.
Longterm upgradability is also a factor, I live 12 miles from a grad strip...
Ernie
Old May 14, 2002 | 01:33 PM
Engine: LS3
Transmission: 6L80E
I can appreciate what you are saying about upgradibility. That is why I searched long and hard before buying my Pro Action heads. Their flow #'s are equivilant to the AFR 210s.
I like AFR for flow...but the budget TF heads will support 450 HP out of the box...on a 406 with a Comp Cam extreme energy 274 cam with 1 5/8" headers...and 500 ft/lb of torque
So you should be ok...In the end, size does matter...plan on building a larger cube engine in the future to take full advantage of the heads...JMHO
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
fonzie85
Aug 13, 2015 11:50 AM
