tpi harnesses
Old May 16, 2002 | 07:01 PM
maddmonkees90rs's Avatar
tpi harnesses
apperantly no one visits the eletronics post. what are the diffreneces between the harness for a firebird and a camaro. oh by the way its a 90 camaro and 90 firebird. what do i have to do to make the firebird harness fit the camaro. thanks for any help
Old May 16, 2002 | 07:49 PM
SLOW5.0's Avatar
Nothing I think. Should all be the same. both made at the same assy line....but I could be wrong
Old May 16, 2002 | 08:51 PM
89Irocz23's Avatar
Well it depends on what kind of harness you mean. Like the part for the lights. On firebird they have motors for the lights and only have one light. The camaros dont have motors for the lights and have a seperate light for the the high beams and low beams.
Old May 16, 2002 | 08:59 PM
no i have the camaro light harness im talkin about the one taht works the engine. like the injectors.
Old May 16, 2002 | 09:14 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Nothing. THe battery is on the opposite side, but other than that nothing..
-- Joe
Old May 17, 2002 | 02:57 PM
89Irocz23's Avatar
yeah the engine harness im pretty sure is the same.
Old May 17, 2002 | 06:55 PM
Jza's Avatar
Jza
Charcoal canister line's on the other side as well. MAF sensor wires (if equipped) may not reach the MAF location on a Camaro depending on how the Firebird was set up.
Old May 17, 2002 | 10:08 PM
no maf... i wouldnt think cus its a speed density harness. wahts the charcol canister for? if i dont need the canister can i illiminate it? is it used for the cruise control and where does thevacumme line for the cc go anyways. thanks
Old May 18, 2002 | 01:26 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I forgot about that, its also on the other side.. ITs used to vent gases from your exhaust tank.. Its a good idea to leave it connected in a FI system, where pressures dramaticly change..
The idea is the gasses are filtered through the charcoal, rather then creating hc's. A vented tank would work also I imagine.
It is an emmisions component.
-- Joe
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
