Taylor Wires
Old May 20, 2002 | 12:02 PM
tpi_roc's Avatar
Taylor Wires
Does taylor offer a wire set precut for L98's with full 90° boots?
Old May 20, 2002 | 12:49 PM
Guest
Guest
Posts: n/a
Why dont you just get a universal set? You can make them fit much better that way.
Old May 20, 2002 | 12:52 PM
tpi_roc's Avatar
I assume they have a universal set with 90° boots then?
Alright I'm on it.
Old May 20, 2002 | 01:57 PM
Guest
Guest
Posts: n/a
They sure do. Thats what I have used on a couple cars. They have sets with all 90's, all 45's, all straight, and I believe they have a mix+match set of sorts. Available in a myriad of colors as well
Old May 20, 2002 | 03:40 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I have found taylors allow more noise to enter your systems than other wires out there :-( this includes l98 as well as turbo 3.8 apps and believe me, they will not last for anything if your running slp headers :-) i just replaced mine in under a mth or so due to the headers being close to the boots on the head end :-) msd makes a comparabl;y priced set that have much sturdier boots , so this is the route i went
later
Old May 20, 2002 | 04:05 PM
tpi_roc's Avatar
Well gawd dayumit!!!
I just ordered the fscking taylors
Old May 20, 2002 | 04:06 PM
3.8TransAM's Avatar
im sorry :-) they sucked it and have lots more rfi interference on everything ive used them on :-( i ditched mine when i did my pickup coil and the msd's run lots quiter noise wise and the boots look a heck of a lot more heat ressistant and thicker as well
Old May 20, 2002 | 04:09 PM
tpi_roc's Avatar
Well I'll be sure to put some wrap on the wires then
Old May 20, 2002 | 05:35 PM
Guest
Guest
Posts: n/a
I've never had a noise problem with them. Nor 'melting' problems.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
