52mm throttle body too big for my combo?
Old May 20, 2002 | 10:37 AM
formul8!!'s Avatar
Car: 2004 GTO
I installed a 52mm throttle body with a hypertech airfoil, and it has seemed to lost some power.
My combo is:
-AS&M large tube runners
-fully ported plenum
-Edelbrock manifold
-SLP CAI
-modified maf
-SLP cat back exhaust
-24# matched injectors w/AFPR
-10" non-lockup 2500 stall converter
-stock 3.27 gear
-Stock heads,cam,exhaust manifolds
I do have SLP 1 3/4 headers in the garage waiting to be installed. I adjusted the TPS and IAC. Timing is at 12 degrees.
I am thinking there is too much air coming in and not enough flow for it to come out.
I'll be going to the track this week. I did not get another baseline with the new mods with the 48mm T/B.
Any input?
Thanks!
Old May 20, 2002 | 10:50 AM
tpi_roc's Avatar
You're likely associating a loss of low end torque for a loss of "power" a 52mm isn't "TOO BIG" for your combo, but your combo sounds slightly off.
Have you prom tuned for those 24lb/hr injectors? I'll bet your BLM's are plenty off and you could recoop alot of power right there.
Old May 20, 2002 | 12:17 PM
formul8!!'s Avatar
Car: 2004 GTO
No PROM burning yet. I have been using the AFPR to control fuel. I have had them on there for about 5 years when my stock GM injectors fried out.
It does seem to have a little more power in the top end. Doesn't wheeze at 4,600RPM's anymore.
Anyone you can recommend to help me burn a PROM? I don't know mu ch about doing it and would rather not play with that stuff myself.
Old May 20, 2002 | 12:20 PM
tpi_roc's Avatar
well im sorry to hear you say that, its been made almost idiot proof, hell im surprised there isn't a "Prom burning for dummies" book yet, but anyways if you truely opt not to do it yourself (Which would probably cost less and be more effective than...) then you should probably go to Ed Wright for a custom chip.
Even though they usually come out running pretty rich
Old May 20, 2002 | 03:45 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
lol ills econd the tune it ourself and ed wright chips come out running rich :-) i know i hhad one burned my own and better off now :-)
As far as a 52mm tb goes why does gm use a 48mm on the ramjet 502 @ 502hp? :-) seems to be beter gains for your money elsewhere in my opinion
later
Old May 20, 2002 | 04:20 PM
formul8!!'s Avatar
Car: 2004 GTO
You and TRAXION should write one!! You guys have so much info on this subject, why not publish it and make some $$ from it??
Old May 20, 2002 | 04:23 PM
tpi_roc's Avatar
You must have me confused with glenn
Old May 20, 2002 | 06:36 PM
formul8!!'s Avatar
Car: 2004 GTO
Let me make sure I am understanding the PROM issues:
With my combo of increased intake airflow and bigger than stock injectors, most likely the ECU is dumping fuel at WOT because the BLM's are still acting like it has stock parts?
I don't get any bogging, but does seem to run rich at all times. The O2 readings at idle are around 250-300 average. I have a friend with a Diacom that can help me tune the fuel curves and spark tables.
I have installed a MAT relocator into the intake bellows. I am sure this may be another source of my tuning issues regarding the PROM?
Maybe Glenn will chime in here....
Thanks for your help!
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
