Hittin' the wall....
Old May 22, 2002 | 12:33 AM
a73camaro's Avatar
of pulsewidth with my injectors. I currently have 19 lb/hr injectors (Bosch 0 280 150 222) in a 383 SBC, with a Procharger, and YES they are too small. I first got the injectors from a 305 TPI and I put setup into a 350. I turned up the pressure so that the injectors would supply enough fuel. That worked for awhile. But not with the 383 SC.
I'm looking for lo-buck 30-36 lb/hr HI-Z injectors. I checked some local junkyards for Ford 2.3 turbo injectors, but they go fast around hear.
Any sugestions except for antie up?
Old May 22, 2002 | 01:55 AM
Guest
Guest
Posts: n/a
I dont know what youre looking to spend...
I got a set of SVO 30#'ers for just over 200 bucks. Not bad IMO.
Old May 22, 2002 | 11:00 AM
tpi_roc's Avatar
I believe jds was selling arm loads of SVO injectors that were matched and dyno ran a few times for about that, $200ish
Old May 22, 2002 | 06:47 PM
a73camaro's Avatar
I tried JD's performance and all he had were 24 lb/hr. Bumping up the pressure to 60 PSI will gives about 30 lb/hr.
Old May 23, 2002 | 12:23 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
TRY EBAY.COM $150-$250 a set most days
Old May 23, 2002 | 02:13 AM
Morley's Avatar
Accel 30# $249
Accel 36# $389
At Summit.
~M~
kzhurley
Sep 2, 2009 12:14 AM
beaverwise
European Region
Jun 4, 2003 01:15 AM
ontogenesis
May 12, 2003 03:56 PM
ontogenesis
May 10, 2003 10:05 PM
