dual-cooling fan-gotta question . . .
Old May 23, 2002 | 05:36 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
on my gta, I'm having a problem w/ 1 of the dual cooling fans (the on on the passenger side) it doesn't work-I went to get a replacement motor, replaced it, and it still doesn't work . . . but the one on the drivers side works-can I rig the 2 wires from the one that works to the one that doesn't work? or will that f-up the fuse system?
thanks for any ideas!!!!!!
Old May 23, 2002 | 08:11 PM
Swapmaster's Avatar
The RH fan comes on when you run the air conditioning.
Old May 23, 2002 | 09:31 PM
91fbirdgta's Avatar
yea, the one on the drivers side comes on for ac and when the car overheats, while the other one doesn't work-
can i splice the wires from the one that already works to the one that doesn't????? will it mess up my fuses???
Old May 23, 2002 | 10:07 PM
87 B4Z's Avatar
i have my 2nd fan wired to come on all the time, works great and i've never had a problem with it.
Old May 23, 2002 | 11:50 PM
Swapmaster's Avatar
Wire it up. Not a prob.
Old May 24, 2002 | 01:11 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Both fans run off the same fuse, FYI. You should be fine.
Old May 24, 2002 | 05:36 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
I hooked the dark green/white wires together between the two fan relays. It's the ground for the relays turned on by the ECM so both fans are controlled by the ECM that way. It's never caused a problem for me.
Old May 24, 2002 | 10:24 AM
91fbirdgta's Avatar
ok sounds good guys!
thanks for all the help; now I know what my next little project is!!!!
Old May 27, 2002 | 01:13 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The transistor life is shortened due to the extra heat generated by dumping twice the current into it. I am not sure of the safety margin GM added on this. Should work though.
J
Old May 27, 2002 | 08:17 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Most of the TPI cars I've gotten with the dual fans, they both cam on at once. A wire was run between both relays, perhaps everyone did the same hack, or GM did. Not really sure, but thats my experience.
My other experience is, 220` is too freaking hot for a motot, unless its on the emmisions dyno ..
-- Joe
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
