Code 42, how to fix?
Old May 23, 2002 | 08:43 PM
WesROCZ's Avatar
My friend ran a code scanner on my car today and it picked up Code 42 and Code 24 (my speedo is not working). How can I fix this? I think this is why my car feels like it has got a miss.
Wes 87 IROC-Z 305 TPI
Old May 23, 2002 | 11:04 PM
gmanrs70's Avatar
have you checked your base timing to see if your timing is right?
Old May 24, 2002 | 12:24 PM
Terry Kennedy's Avatar
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
Well first make sure your brown wire is plugged in. If it is then clear your code's by disconnecting your bat. Then check your codes again. As for the 24 that's because your speedo doesn't work. I have the same 2 codes right now, easy fix though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
