Speedometer calibration
Old May 28, 2002 | 05:56 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I posted this on the tranny board, but I was hoping someone here may have some insight also.
I just did a gear swap in my firebird, from 2.73 to 3.42.
What exactly do I need to do to make the speedo read correctly?
It's the electric one, not cable driven.
Do I need to change the gears in the tranny, or do I need to change something in the speedo itself?
The car is an 89 formula 350, the wheels and tires are stock sizes, and the tranny is a stock 700r4.
I've asked several mechanics and all I get is a lot of head scratching and dumb looks
I also searched the archives, and there is so much information in there I started to get confused.
Thanks for any help
John
Old May 29, 2002 | 08:58 AM
dd85T/A's Avatar
Car: 85 T/A
I used a Dakota digital box. It works great. You can change the gears in the tranny but that really sucks.
Old May 29, 2002 | 01:54 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
All you need to do is change the gears in the tail housing of the trans. It can be a pain because of a little clip you have to watch out for though. Go here for directions: http://www.sethirdgen.org/vss.htm
I am not sure on the correct gears you need though. The dealer can help you with that.
If you don't have a 32mm wrench.. buy one!! I broke the drive gear using other methods to install it.
Old May 29, 2002 | 04:30 PM
Thanks, thats the information I needed, I ordered the parts today from the chevy dealer.
John
Old May 29, 2002 | 06:49 PM
Omega's Avatar
Engine: LS1 / LS3
No problem
Old Jun 1, 2002 | 08:21 PM
Update: The gears didn't fit, the new driven gear is a 1/4" larger than the old one, I need to change out the sleeve as well.
Old Jun 2, 2002 | 12:02 PM
Vader's Avatar
Whatever gets you 2,000 pulses per mile will get your speedo just about perfectly calibrated (well, 2,002 actually).
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
