tpi swapping problems
Old Jun 1, 2002 | 04:19 PM
maddmonkees90rs's Avatar
here we go again..... so im just about to finish up the swap. now i put the key in and no power. well sorta.... i think the fuel pump primed but the engine did no turn over. no power to the starter. is the starter disabled by the vats, are the proms from gmpartsdirect.com come with vats or are they disabled? thats where i got my prom from. i thought it disabled the fuel pump. is it the starter? what should i look for and how do i correct it? thanks for any help guys.
Old Jun 1, 2002 | 05:10 PM
Guest
Guest
Posts: n/a
Check the wires at the starter, you may have hooked them up wrong... that is if you have 12v on the main cable anyways. I couldnt tell you which is correct, I always forget myself.
Old Jun 1, 2002 | 11:38 PM
rockind78's Avatar
That depends what year your PROM is for. They started VATS in '89 I believe.
Old Jun 1, 2002 | 11:44 PM
rockind78's Avatar
Sorry, double post.
Old Jun 3, 2002 | 04:51 PM
ttt. help please
Old Jun 3, 2002 | 05:23 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
What year is your car and what year is the TPI setup? I had the same exact problem about a month ago....and checked EVERYTHING that it could possibly be....and it ended up being the last thing i checked But let me know and I can give you quite a few ideas.
Old Jun 3, 2002 | 05:34 PM
car 90 rs
tpi setup(plenum runners and base) 87
harness 90tpi (i want sd)
ecm its 90tpi bought the chip(eprom) for it from gmpartsdirect
need any other info? thanks for any help
Old Jun 3, 2002 | 06:08 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Originally posted by maddmonkees90rs
car 90 rs
It's a possiblity it's vats since you have a '90 computer. That wasn't the problem w/ mine because I used an '87 computer. What is it doing w/ you turn the key? Is it trying to crank up...or is it just dropping dead not making a sound? On mine it ended up being the little hose in the gas tank connected to the fuel pump...it busted causing me to get hardly any fuel pressure. I'm assuming you got a new fuel pump for TPI correct? Check your fuel pressure...and that will tell you if it's something w/ the pump/lines, or if it's vats. There are other possiblities, but I can't name them until I know exactly what your car is doing when you turn the key.
Old Jun 3, 2002 | 07:46 PM
i think it does nothing , i needa double check. but im sure its not. think its the vats? thanks
Old Jun 3, 2002 | 08:34 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Well if it had something to do w/ the fuel pressure, the car would at least TRY to turn over. Oh, and I hope you replaced that little piece of rubber hose in the gas tank w/ high pressure hose....cause it will bust.
Well if your car is doing NOTHING....then the cause is more than likey loose wires at the starter, or VATS. Crawl under the car and tighten all the wires on the starter and hopefully that's the problem (probably not). If it is VATS, there's a few ways to disable it, the simplest to get a chip burned disabling VATS....ask around in the DIY PROM board and see who can do it for you at a reasonable price. Another option...if you can get the original key that went w/ the car w/ your computer, you can take it to a dealership, and get a new key made to fit your car, but w/ the correct chip for the ECM. But dont just automatically jump to the conclusion that it's VATS and go out and spend the $$$ for a chip...check other things...like whether or not it's getting spark.
customblackbird
Aug 15, 2021 10:16 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
