my "new" plenum cover
Old Jun 2, 2002 | 04:23 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
finally figured out how to do this stuff! thanks for being patient with me while i played retarded! well here she is. looks pretty nice with the plenum i polished today. i will post pics of my plenum some other time. it is polished with red stripes painted in between the fins.
Old Jun 2, 2002 | 08:36 AM
Kevin G's Avatar
You need to upload that pic from your C: drive. The tags will not work that way.
Old Jun 2, 2002 | 08:55 AM
TransAm87's Avatar
yup, try again
Old Jun 2, 2002 | 11:35 AM
Vader's Avatar
The file location you specified needs to be in a web-based directory, not on a local drive. If you have storage space on a web server somewhere, copy the *.jpg to a directory there, then use that link in the image callout.
If you can trim the image file to something under 100Kb, you can attach it to your post.
Old Jun 2, 2002 | 05:06 PM
johndo1707's Avatar
i wanna see this thing
Old Jun 2, 2002 | 06:24 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
here you can see mine. powdercoated and polished.
http://www.fl-thirdgen.org/MRR23-4.HTML
Old Jun 2, 2002 | 07:36 PM
ZZsmpch's Avatar
Can the metal dist. covers be polished, or will it look crappy?
Old Jun 3, 2002 | 10:51 AM
Desert86Roc's Avatar
You must have posted the wrong pic... All I saw was a painted throttlebody plate.
Old Jun 3, 2002 | 05:45 PM
oops!
okay so i called it the wrong name, sorry guys. but i did polish my plenum and will post pics as soon as i can. so anyway, you didnt say what you thought of the TB cover plate...
Old Jun 3, 2002 | 06:41 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
honestly, it looks like it's sprayed with a $2 bottle of krylon.
Not my taste at all.
I have an anodized blue plate on my tb, it says BMR Fabrication.. (where I got all my suspension components from..)
Old Jun 3, 2002 | 07:07 PM
Lounge Lizard 6's Avatar
I realize this is off topic and everyone's pardon, but I've been seeing this typo in mrr's sig on several sites for quite some time: 177.7hp 356.4tq. According to your own dyno sheets it's 256.
I figured it was just a typo that you would want to know about.
Old Jun 3, 2002 | 09:45 PM
mrr23's Avatar
Engine: 360 HSR
look harder. it's blurry, but it is 356ft/lbs. this was in 3rd gear auto. also look at the purple line that drops sharply. that's the torque line. the torque graph is on the right. it starts just above the 350 line.
on the third graph show the exhaust mod improvement. it was in 2nd gear and it was 285.3ft/lbs
but, thank you for looking out.
Old Jun 3, 2002 | 09:57 PM
mrr23's Avatar
Engine: 360 HSR
i polished the ribs on mine.
www.fl-thirdgen.org/mrr23-4.html
Old Jun 4, 2002 | 12:28 AM
ZZsmpch's Avatar
Looks nice. I wasn't sure it it would polish up or if would need to be plated. I just started on the plenum and was going to try the cover for the hell of it. I figure at worst, I'd be out 15 bucks and get another one. Thanks.
Old Jun 4, 2002 | 10:41 AM
tpi_roc's Avatar
wtf.....
all that suspense for a spray painted throttle body plate?
Old Jun 4, 2002 | 07:42 PM
mrr23's Avatar
Engine: 360 HSR
thank you. i first used an air grinder with roloc abrasive pads. then used 320 grit, 600, 1000 wet, 1500 wet sanding. then used a high speed polish wheel to finish it out.
Old Jun 5, 2002 | 09:50 AM
this is BS
ya'll are bein pretty mean to an ol country boy. i am new to this forum and i figured i might get treated a little bit better than this. the damn plate is NOT spray painted. I painted that BY HAND, letters and all. maybe i dont have thousands upon thousands of dollars or some big fancy shop like you guys to make my car run 12's or what-have-you but dammit im tryin.
Old Jun 5, 2002 | 11:29 AM
tpi_roc's Avatar
Haha
I dont have a shop
I work on my car outdoors
Old Jun 5, 2002 | 11:48 AM
rockind78's Avatar
Originally posted by tpi_roc
wtf.....
tpi_roc, just a little harsh don't ya think? I for one value your knowledge in this forum, but give the guy a break. ScreaminFormula, I personally don't find the TB plate to be my "cup of tea" sort of speak, but I do respect your efforts, and the only truly impoprtant thing is that you like it. To hell with what everyone else thinks. If I cared about that, I would have never bought a 4-door Chevelle, because on the way home from Texas, I was getting reactions like tpi-roc's all the way home. BUILD WHAT YOU WANT AND ENJOY IT!!!
On another note, you will find that although tpi_roc and the others are a little critical right now, you will find that their knowledge can be quite useful in helping you solve any problems you may encounter. I read a lot of posts and most of them are pretty sharp.
Old Jun 5, 2002 | 11:58 AM
Morley's Avatar
Instead of painting the background of it black, you may want to try polishing it to a high sheen and then hand painting the lettering the same color as your car. I've seen this done and it looks very sharp.
~M~
Old Jun 5, 2002 | 12:58 PM
tpi_roc's Avatar
Sorry
My sense of humor is very often mistaken for being an as5hole, keep that in mind as you read my posts in the future.
I play around to much, try to keep it light
Old Jun 5, 2002 | 12:59 PM
tpi_roc's Avatar
Hell in "PM" I even offered to host that picture for him so he could get it up.
Old Jun 5, 2002 | 01:18 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm going to give some constructive criticism here. I think it looks sh!tty too, but lucky for you, it's real easy to fix that problem. First, get some airplane stripper (aerosol can, Advance Autoparts, about $5) to strip off your paint. Make sure you get ALL The paint off, even from within the nooks and crannies. Once you're back to bare aluminum, sand the flat area with some 180 grit sand paper to smooth out any of the rough casting. Resand with 220 grit sand paper. Buy a spray can of automotive primer, and a spray can of gloss black paint. For this application, I'd probably use an exterior gloss black color that's available on the "touch up" rack, but black engine paint or even good old Rust Oleum will work fine.
Once it's sanded, give it a light coat of the primer and wait about a half hour, then give it another light coat. The piece should have even coverage, and if you didn't drown it in primer, should look pretty good. Give it an hour to dry, then give it 2 or 3 light coats of the black paint, again making sure not to drown it in it. Let it dry, then you have a couple choices. You can take a block sander with some 400 grit sand paper and sand the "TUNED PORT INJECTION" raised letters until you've got the bare aluminum showing through. That's easy, and looks great. Or, if you like the red, brush the red on like you did already.
For a few bucks and a little time, you can have a professional looking plate instead of one that looks like a 10 year old's art project. Best of all, you'll have all the materials in stock for when you want to paint up some other things, like brackets and pulleys.
Old Jun 5, 2002 | 07:35 PM
rockind78's Avatar
Sorry
Will do. Just didn't want the new guy scared off.
Old Jun 6, 2002 | 01:23 AM
im sorry too...
I had just had a really bad day yesterday and took it all wrong. today wasnt much better. my speed sensor let my T5 puke up all its fluid, turns out the threads had to be heilicoiled, which i did myself. then on the way to get a new speed sensor (mine only had half the gear left on it!) my clutch started slipping and a mustang gt (99-01 model) dang near outran me. turns out i need a new rear main seal and clutch, which i bought today. then when i got the darn speed sensor it DIDNT come with the drive gear so i had to go to my local friendly Pontiac dealer and order
one; i'll have a speedo again this saturday...so now i have a real busy weekend! and to top it off my platoon is running 7 miles saturday morning! well ill chat at ya'll later...
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
Nick McCardle
Sep 10, 2015 08:36 PM
