What??? 2 Different Super Ram Plenums??
Old Jun 3, 2002 | 08:30 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I wrote to the Accel tech dept. about my wiper motor no longer fitting since I installed my Super Ram. I already tried flipping the motor mounts and trust me when I tell you it wouldn't fit even without them all together.
Anyways Accel gets back to me today and tells me that there are 2 different Super Ram plenums and that the 1 for the F-Body is 1 inch shorter (2 inch instead of 3 inch) than the standard one.
Anybody heard of this? Will the smaller plenum cut down on my airflow/volumetric efficiency? Should I sacrifice power just for a stupid wiper motor??!!
Old Jun 3, 2002 | 09:31 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Maybe they are talking about the plenum made for the LT-1 SuperRam kit The Mr. Gasket customer service is terrible.
Old Jun 3, 2002 | 09:32 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
You have no clearance between the back corner of the SuperRam and your wiper motor? As in they touch?
Old Jun 3, 2002 | 09:46 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You need to use a newer style wiper motor. 87-up I think, but I might be off on the year.
Old Jun 4, 2002 | 11:17 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
My Super Ram is close to the wiper motor, but it still fits. There was only one type when I ordered it from Lingenfelter on 6/2000.
Old Jun 4, 2002 | 02:24 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
It's close on mine but it fits.
Old Jun 4, 2002 | 07:47 PM
Car: 89 IROC-Z
Engine: 383
I have an 89 wiper motor. The 87 and older fit because they don't have delay and the plug comes out on the other side, but I want to keep my delay.
And yes I do mean NO clearance at all. The only option I have found so far is the kit at www.detroitspeed.com but I can't swing spending over $300 on a damned wiper motor kit.
Old Jun 5, 2002 | 08:55 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
My 90 has the delay wipers and the motor clears the plenum by about 1/2" with the rubber feet swapped to the outside. The plenum for the 4th gen LT1 cars is lower.
Maybe there is a smaller factory motor you could swap it out for.
Old Jun 5, 2002 | 11:28 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Mine clears an '87 wiper motor (that has delay), and I didn't need to mess with the rubber mounts at all. I have about half an inch clearance also.
Since these things are cast, they are all a little different. Maybe you just go one that is just "off" enough.
Good luck.
Old Jun 6, 2002 | 12:04 AM
89ProchargedROC's Avatar
why dont you order a new plenum and if that is the problem talk with a customer service rep and let him allow you to return the old one that doesn't fit
Old Jun 6, 2002 | 07:45 PM
Car: 89 IROC-Z
Engine: 383
Ordering another plenum is a possibility, but that could leave me with 2 plenums that don't fit or 1 that does and 1 that doesn't if I can't return the original one. Plus I would like to try and figure it out without taking that thing off for a third time....although I'm getting much better at it!
Could it be possible that my wiper motor casting is slightly too large??
Old Jun 8, 2002 | 09:30 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Yeah, I would look into a different wiper motor, maybe there are some with delay that are smaller. Paul...How long is your plenum from front to back?
Old Jun 8, 2002 | 09:49 AM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
I have had the same problem with the SR. I took the rubber inuslators off the wiper motor completely and the SR still touches the wiper motor right where the plug is. The SR is in an 89 ontop of a 408 with just new stock motor mounts.
A few years ago I have heard people having problems with the wiper motors getting in the way. My temp solution was cutting the plug almost completely off and and taking the female side of the plug apart and running each individual wire into the male part on the wiper motor itself. Looks like ****, but it works as a solution right now.
Might not be able to see the it in the pics to well but you can look here to see what I did:
http://www.cartogra.com/home/ViewMyAlbum.asp?coll_id=1542494
Old Jun 8, 2002 | 02:28 PM
go look at photo 4 and click towards the wiper motor and you'll see a good pic of what he did
Old Jun 9, 2002 | 07:53 PM
Car: 89 IROC-Z
Engine: 383
Thanks for the ideas but I don't want to go hacking up my wiring harness or factory motor yet. I e-mailed the company I got my SR from to see if they will send me another plenum.....hopefully I will hear back in a day or two.
As far as getting the measurement of my plenum....it will be a few days because the car is back at the paint shop being buffed out and having the decals/stripes applied.
Does anyone know if there are any other GM wiper motors that would have the same 2 connections as my factory unit?
Old Jun 9, 2002 | 11:31 PM
CHCKLS's Avatar
Engine: 409 SR
The harness is not hacked up on my car. Just the reciever plug on the wiper motor. I can still put the plug back to together on the harness side.
Old Jun 10, 2003 | 10:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Im bringing this post back from the dead after doing a search. I have the energy suspension replacement motormount biscuits and yes they are in the right way. My car is a 92 B4C (same as Z28). There was atleast an inch of interference which has been reduced to about 3/4 inch by doing the bushing trick. If I unplug the motor it leaves about 3/8ths of an inch still to come up with. Im faced with two obvious options both seem kind of severe. one is to remove the plug and cut down the wipermotor side of the plug receptacle. this would require that I hard wire the wiring to the motor. Option two is very severe and requires that I have a friend at a shop sections and weld the thing and have it polished to cover up the work afterwards. I think this will give me all the clearance I need, anyone come up with a better solution? Maybe a different year or model of wiper motor that offers more room? suggestions needed badly before I do major crazy surgery to make this fit...
Old Jun 10, 2003 | 10:56 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here:
Attached Thumbnails What???  2 Different Super Ram Plenums??-clearance-2-.jpg
Old Jun 10, 2003 | 10:57 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
and here:
Attached Thumbnails What???  2 Different Super Ram Plenums??-clearance-1-.jpg
Old Jun 10, 2003 | 11:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Dude I had the ES motor mounts and had to get rid of them. Also I think ya screwed yourself... How you going to get the TV cable underneigth? i put my plenum on and forgot the TV cable and I couldnt get it underneigth. I had to pull it back off....
Old Jun 10, 2003 | 11:44 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I didnt screw myself yet as my plenum is merely polted together properly but using only about 8 fasteners for mock up purposes. you think I need to get rid of my ES mounts to resolve this? I guess I could go buy some new anchor brand stock ones slip them and call it good? anyone else?
Old Jun 10, 2003 | 11:47 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Phew.. Well thats good. Well I went back to the stock mounts and my plenum still touches, but not bad. The ES was so high my TB was hitting my hood (firebird hood)
Old Jun 11, 2003 | 01:01 AM
if you end up going to the stock mounts...let me know. I think i could use those ES mounts possibly
let me know
Old Jun 11, 2003 | 01:17 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah because I wanted to go moroso solid on the 91 street legal drag car. so Im not sure what I will be doing.
Old Jun 11, 2003 | 01:30 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
and yes procharged if I cant use them you get them
Old Jun 11, 2003 | 06:43 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Originally posted by B4Ctom1
and here:
I actually had to grind mine down back there.
Old Jun 11, 2003 | 03:59 PM
Car: 89 IROC-Z
Engine: 383
I had the same issue with my car. I also have polygraphite motor mounts. I just cut part of the connector off of the wiper motor if I remember correctly. There is a very small clearance for mine now, but I've been driving it a year with no problems. Don't forget, the motor torques away from the wiper connector anyway.
Old Jun 11, 2003 | 06:04 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
good point
Old Jun 12, 2003 | 06:05 AM
Z_Ghost's Avatar
I have the poly motor mounts on my car and I had to grind the back of the plenum down, it’s really thick back there and I was able to take off about 3/8 with my die grinder.
I also had to cut the wiper motor faceplate down some too.
Old Jun 13, 2003 | 10:58 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
looks like IM going to be buying some Autozone "anchor" brand mounts like $8 each :-(
Old Jun 14, 2003 | 09:19 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Too bad you guys are having a hard time with this, all I had to do was pull the grommet off one corner and it cleared.
Old Jun 15, 2003 | 01:40 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I wish it was the same for everyone. it seems like varying degrees of modifications were required in almost every case so I am just pulling the ES mounts and going with stock ones.
Old Jun 15, 2003 | 02:00 PM
OMINOUS_87's Avatar
I just dropped my motor in yesterday. Had the wiper motor unbolted when the motor was dropped in. It does look damn close with the SR in place. I am just going to leave it out and pull the wipers off Vs. toying with it. I do however live in Phoenix AZ and it might rain 12 or so times a year here so it is not all that critical to me, thank ***! However getting the AC system back up and running to fight the 105-110 degree summer wheather will be a challenge, dammit!!!
Old Jun 15, 2003 | 03:54 PM
Z_Ghost's Avatar
I should have taken a pic before I put the plenum on the motor, but here it one as it sits.
If you look close you can see how much I ground off the backside, it's close but just enough room to clear.
Old Jun 15, 2003 | 04:05 PM
OMINOUS_87's Avatar
Z_Ghost
Did you install the plenum and runners while the motor was in the car? I dropped mine in complete, put it together on the stand first
Old Jun 15, 2003 | 04:13 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I almost did that but I was waiting on parts to put mine on other wise I would have had to make a "where is the cheapest place to buy a wiper motor" post LOL
Old Jun 15, 2003 | 06:39 PM
Z_Ghost's Avatar
I put the SuperRam on after the motor was in the car, I wanted to move a lot of the wires and that would not have been possible to do with the plenum on the motor.
Old Jun 16, 2003 | 02:20 AM
OMINOUS_87's Avatar
Forgot to mention that! I layed down the TV cable and hooked up wires to my blocked off EGR, yes the EGR valve will clear the SR plenum with a block of plate underneath it, along with the vaccum lines, and of sourse the IAT. I dropped in the new motor along with a new trans at the same time so the TV cable didnt spoil my plan.
It was enough fun putting the damn thing together on the stand, I will reserve an on car teardown or install for a need be situation, hopefully that never comes to be.
Old Jun 18, 2003 | 07:46 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
smart move on that EGR, well I bought my new anchor brand stock mounts at the local CSK store and tomorrow if Im off they will go in.
Old Jun 18, 2003 | 11:01 PM
OMINOUS_87's Avatar
B4Ctom1
Your gonna ditch the poly mounts? That trade off sucks, *** damn Superrams! I think back to the 20 hrs of porting, loosing the wipers, cleaning the used parts I bought, and spending alot of time bolting it together and I figure I just should have went Stealthram. Not, the Superram makes the best average numbers under 6000rpm, priceless for a street car. Ill take a few trade offs as well.
Old Jun 19, 2003 | 12:41 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
thats why I got an HSR for my 91 drag car project. Besides I like to tear up or tear into my chit once in a while, you think I really wanna hassle with the superram on the race car 'blech'
Just for S's & G's I put the HSR ontop of the cruisers 412 for a picture
Old May 19, 2019 | 09:10 AM
  #42
CHCKLS's Avatar
Engine: 409 SR
Re: What??? 2 Different Super Ram Plenums??
Hi , here I am 17 years later. Was it ever confirmed that there were 2 different size plenums? Just curious as I am getting back into this and making some changes to the car.
Old May 19, 2019 | 09:20 AM
  #43
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Yes, there are two different plenums
Old May 20, 2019 | 03:38 AM
  #44
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Are we bored today?
Old May 24, 2019 | 09:52 PM
  #45
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Holy old thread Batman, lol! All these years of owning one i never knew there were 2 different plenums! Is there a way to tell the difference? The one on the motor in my 91 hit the wiper motor, so i just cut the mounting bushings down for clearance
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
