whats the max lift for stock iron L98 heads?
im choosing a cam and dont know the max lift that the stock iron L98 heads can handle. if i want to go to something a little higher than the max lift of the heads, what machine work do i need to have done? can i get away with just a stiffer spring or will i need more? thanx
i am torn between the ZZ9 and LT4 cams. with 1.5 rocekers, the specs are:
ZZ9 212/216 dur@.050" .483/.520 lift 112' sep.
LT4 218/228 dur@.050" .492/.492 lift 12'sep
which of these do you guys reccomend and what mods need to be done to the stock heads. could i get away with LT4 if i just used a stiffer spring? if so, how stiff? thanx
1988iroc350tpi
Aug 14, 2015 07:52 PM
