afpr
Old Jun 8, 2002 | 12:32 PM
fourspeed's Avatar
afpr
i know there is an article on making the stock unit adjustable but i wanted to hear what everyone thought about the other afprs on the market before i install one
thanks
Old Jun 8, 2002 | 12:38 PM
Morley's Avatar
Of all the ones I have seen for sale, the Accel unit is the only one that gives you a new diaphram, instead of using the old one.
~M~
Old Jun 8, 2002 | 12:40 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My only concern with making your own is that there wouldn't be enough material there for the screw to thread properly. Otherwise it's pretty much a no brainer... well, actually, because of the quarter you've got to place in there, even backed all the way off, your fuel pressure would be higher than stock.
As for aftermarkets.. they're pretty much all the same. I can't remember what brand my first one was, but the cup was a good sturdy piece of aluminum. My only complaint is that the screw it came with stuck up so high it hit my plenum. Now I've got another brand (don't know what brand this one is either... I got it used) but it looks basically the same except it's bare aluminum, which I promptly polished.
Old Jun 8, 2002 | 02:11 PM
kevinc's Avatar
Car: 1982 Z28
The Holley AFPR comes w/ a new 2-layer diaphragm and spring, and it's much lower profile and easier to adjust than the traditional "bolt thru the cap" type.
Old Jun 8, 2002 | 08:51 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
agreed. i just swapped out a Hypertech unit for a Holley one. much better design. its much more durable and easier to adjust tha the other bolt types. just dont try to adjust the "thumbwheel" when your engines hot. yeeeow!!!
Old Jun 8, 2002 | 08:56 PM
Jim85IROC's Avatar
The one thing that I like about the other brands, is that they use the stock FPR hardware. I like using parts that local stores keep in stock instead of stuff that's a week away.
Old Jun 9, 2002 | 09:25 AM
Vader's Avatar
That's why a jamb nut is brazed or silver soldered to the spring can. And it you use the ball method or reshape the can according to instructions, you can adjust pressure to well below stock specs as well as the high end:
TPI-AFPR.pdf
Old Jun 9, 2002 | 07:27 PM
rondubbs's Avatar
The TPIS one Sucks
Old Jun 9, 2002 | 08:41 PM
kevinc's Avatar
Car: 1982 Z28
You get callouses after a few times. The cheesy-looking "Mechanix" gloves actually do a good job of saving your hands and get good grip on the Holley's adjuster hat.
Old Jun 11, 2002 | 10:39 AM
Sauron91's Avatar
How much will an AFPR help performance?
Old Jun 11, 2002 | 10:50 AM
tpi_roc's Avatar
I made my own adjustable one about a year ago and have yet to have a problem with it.
Old Jun 11, 2002 | 10:56 AM
kevinc's Avatar
Car: 1982 Z28
It will help you fix <b>100%</b> of your fuel overdelivery or underdelivery problems if you have any.
Old Jun 11, 2002 | 12:03 PM
tpi_roc's Avatar
It will?
Do tell
Old Jun 12, 2002 | 02:09 PM
kevinc's Avatar
Car: 1982 Z28
Yea, it was kind of a smartazz answer....
If you are underdelivering fuel, you can dial up pressure and compensate. If overdelivering, dial it down.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
