lt1 intake swap complete, but
Old Jun 10, 2002 | 07:58 PM
strokedsmoke's Avatar
as it says the swap is done and works great, but there is a problem with how it idles. The speed doesnt adjust right and it idles rough compared to before, and i was wondering if it was because i relocated the manifold air temp sensor to the rubber air duct (since i didnt see a place for it on the new manifold) between the MAF and throtle body, if there is a vacum leak can it cause this. Any help or recomendations would be great.
Old Jun 10, 2002 | 09:26 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The idle can be tuned via chip programming. If your running the stock prom the computer is most likely very confused right now.
Old Jun 11, 2002 | 10:31 AM
tpi_roc's Avatar
Preach it brutha
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
