peanut cam?
Old Jun 16, 2002 | 07:43 AM
dale davidson's Avatar
peanut cam?
hello, i was doing some searching and found that the higher output lb9 was found in the '85 f-bodies. well, the old inspection sticker on the t/a says that its an '86 but the tach does not yello line until 5000 rpm, could this be possible?
the second thing is the throttle response, i believe that the engine revs slow as compared to my carbureted t/a and it also seems to wind up slower under a no load condition, but when its in gear, it does its job. would there be anything i can do to get a more lively revving engine? or should i adjust the throttle cable, thanks.
Old Jun 16, 2002 | 12:06 PM
Guest
Guest
Posts: n/a
Adjusting the throttle cable wont improve the throttle response unless its just plain loose. I really doubt that it is.
The cam in 86's is the peanut cam. My 86 tach yellow lines at 5000 too, its not a good indicator to go by as to what the engine is capable of.
Old Jun 17, 2002 | 06:34 AM
thanks, well i was doing some searching and i basically came up with changing the position of MAT? for better throttle response, but where is it located on th TPI?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
