Fuel Line Fittings for Stealth Ram?
Old Jul 1, 2002 | 03:02 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I would like to know what -6AN fittings I would need for the fuel rails feed and return lines? I would probably need 2 90 degree for the lines on the fuel rails. I would also like to find out what -6AN fittings I need to screw into the stock solid fuel and return lines on the drivers side frame rail. I reall dont want to cut the lines and would like a 45 degree bend on those to avoid the headers and make it look cleaner.
Thanks!!!
P.S. Anyone interested in purchasing a new in the box fuel rail kit for the stealth ram??? Email me at lrnelson5669@attbi.com
Old Jul 1, 2002 | 09:57 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
hey slow you should check out my post, I posted some pics of my set up. I didn't cut my fuel lines either, I used the the stock set up on my fenders. The fittings they use in the kit are Hydraulic fittings, you can take them to a hose shop and get them to fab you some lines, they will bolt up to your stock lines and to your fuel lines, but I ran mine to the front. I don't know if thats what you wanted to know, but hopes it helps.
Old Jul 1, 2002 | 10:16 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
dacuma I have been following you post but there are no hose places around me. I need the AN adapters so that I can run braded line.........man this swap is tough....
Old Jul 1, 2002 | 11:44 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Do I just need an AN to pipe thread adapter.....???????
Old Jul 2, 2002 | 04:11 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Here you go the top two are the ones I used http://www.holley.com/HiOctn/ProdLin...A/9894DBH.html
Old Jul 2, 2002 | 09:50 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Do I need any adapters for the ones on the fuel rails? Or can I just buy a 90 degree -6AN fitting and it will screw onto the rails?
Old Jul 2, 2002 | 01:38 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
hey do you have any hose shops near you, or even tracktor places if you got a john deer near you just bring in your inlet and outlet fittings and see if they give you the female ends with a 90fitting and a strait fitting.? Yeah it is pretty tough, I was lucky that my buddy works with them, and new what they were right off the bat. If I remember right -6AN is a 3/8 fitting, hey check in the phone book and see if you got any. Dang man hope that everything works out. I've been there done that, trust me it gets better once you get your lines made up.
Old Jul 2, 2002 | 04:12 PM
e-man's Avatar
Car: 89 formula
Engine: 383
The fittings are regular -6AN any hose end from Earls,Russell,Aeroquip will fit.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
L98GTA87
Aug 11, 2015 06:55 PM
