Fitting from stock solid fuel lines to AN fittings????
Old Jul 6, 2002 | 01:41 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I am installing the stealth Ram and need the fittings to go from the fuel lines on the frame rail on the drivers side to a AN fitting. I was told to get these but one works and the other doesnt. They only fit on the smaller line and it wont go over the larger line line where the o-ring sits. I ordered the top 2 like I was told from here ..... http://www.holley.com/HiOctn/ProdLin...A/9894DBH.html
Can anyone help?? It is an 89 Iroc-Z if it matters!!!!!!!!! Help...I wanna be ready for the MFBA US41 track rental on the 13th.
Old Jul 6, 2002 | 02:25 AM
89ProchargedROC's Avatar
LOL, we have a track rental on the 13th?
man i have to check out the events section more.....
they probably sent you the wrong one then.....how far is burbank from chicago? i could come help you install it
Old Jul 6, 2002 | 12:42 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Burbank is about 10mins south of chicago...I am on 87th St. and Moody Ave. What part of chicago are you from?
Old Jul 6, 2002 | 07:25 PM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
I used these: http://www.jegs.com/cgi-bin/ncommerc...14&prmenbr=361
and set up everything like this:
Old Jul 6, 2002 | 10:40 PM
Except the sad thing is, is that you paid almost double for the same fittings that just aren't labeled "TPI"
which are these:
http://www.anplumbing.com/shop/shop1...d=Fuel Adapter
its the top 2 listed on the page
Old Jul 7, 2002 | 11:41 AM
e-man's Avatar
Car: 89 formula
Engine: 383
I used the top two from earls and they both fit the 16mm was for the feed line(bigger one) and the 14mm was for the return.
Old Jul 8, 2002 | 08:26 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Any luck with the lines?
Old Jul 9, 2002 | 12:51 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
I didnt get the new adapter from Summit yet...gotta wait and see...............................
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
R3500
Aug 17, 2015 12:16 PM
armybyrd
Aug 10, 2015 09:23 PM
