tpi 327 good idea???
Old Jul 7, 2002 | 12:26 PM
pokes87iroc's Avatar
well i want to build a motor for my 87 iroc im not sure what i want to do yet i was thinking 302 327 355 383 400 or just a 350 what would be a good one to run with a tpi setup thanks
Old Jul 7, 2002 | 12:31 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I wouldn't run TPI on anything bigger then a 350. Also if you engine is going to be any better then a stock 350 I would buy some aftermarket TPI parts like runners and a new base.
A 327 is not cost effective, don't bother with one.
Old Jul 7, 2002 | 01:33 PM
iroc22's Avatar
A 327 and 350 will make similar power levels. The 23ci difference doesn't play a huge role. You'll find the 327 will rev slightly higher and the 350 will make slightly more torque.
All in all though, the 355 seems to work the best with a TPI setup.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
