Stripped out screws on 85 tpi
Old Jul 7, 2002 | 11:38 PM
cllimp101's Avatar
I have a 85 z tpi and i was just going to clean the whole intake and take it apart to get it back to normal, i took out the bolts that u need the torque screw for but there are two that are totaly stripped to circles and i cant get them out.?? any ideas on how to take them out , i have tried using bigger size and hammering it but it still keeps on stripping the screw. I also need to know where i can get new torque screws for when and if i get it out. THnx.
Old Jul 8, 2002 | 01:25 AM
rockind78's Avatar
Got a picture? I am not sure what you are talking about.
Old Jul 8, 2002 | 07:29 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Grind a slot into the bolts and use a slotted screwdriver attachment for your ratchet. Make sure you grind the slot deep enough the first time, because if you f*ck it up with the slotted screwdriver, you're really in for a major hassle.
Old Jul 8, 2002 | 09:14 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Air chisel works too if your carefull.
-- Joe
Old Jul 8, 2002 | 11:09 AM
cllimp101's Avatar
thnx for the tips but i did that with my dremal and i still cant get it
I guess i am going to have to tke it somewhere or something to get it fixed. Do u guys know where u can get more screws for it , new ones? Thnx again
Old Jul 8, 2002 | 11:44 AM
Jim85IROC's Avatar
If you want torx screws, you're going to have to go to the dealer, but if you can settle for allen head, any good hardware store should have them.
Old Jul 8, 2002 | 12:41 PM
cllimp101's Avatar
ok. i dont care what kind of head they have as long as it fits .
Thnx again. One more quick question what would u guys use to clean the plenum and runners with?
Old Jul 8, 2002 | 01:11 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
If you have access to a welder, just try welding a nut on top. JB Weld might even do it.
Old Jul 9, 2002 | 12:06 PM
Desert86Roc's Avatar
Ever heard of an easy-out, or a screw extractor? You can pick up a set Checker or Autozone, but they usually break. Get a good set and the Easy-out will probably work best.
Now would be a good time to get rid of your button head torx bolts....use some nice stainless steel socket caps. pic below:
Old Jul 9, 2002 | 10:56 PM
rockind78's Avatar
Man I am an idiot sometimes I know what you are talking about. The guy at my machine shop does it for $10 a pop. Not too bad I think.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
