Rebuilding 305
Old Jul 15, 2002 | 09:26 AM
86TATpi's Avatar
Rebuilding 305
I have a 305 Tuned Port all stock. I'm trying to decide what would be the best move for the engine. I want the 5.0 for the sake of keeping it original. I was wondering what I could do when I have it rebuilt so that it has at least mid 300 horse?
Old Jul 15, 2002 | 02:34 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Why keep it all original? It's not like it's a collector's item. 1986 TA's are plentiful. A rebuild on a 305 is probably more expensive than a 350, so just build one of those and use your 305 as a yard ornament or a paperweight.
Long story short.
350
modified vortec heads with springs
HOT Cam
SDPC2000 TPI base
Headers
22 lb injectors
Old Jul 16, 2002 | 10:47 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
If you rebuild it in a way that increases it's output i.e. different pistons larger valves etc. then you are in fact making it non original and negating your reason for keeping it a 305. I would say take the original motor out of the car and rather than rebuild it, set it in storage and just put a different one in(whatever engine you chose) that way if you decide to take it back to "original" you'll have the original engine.
Hodge
getting a 350 or 305 core is fairly cheap and rebuilding it will cost around the same. the 350 may actually be cheaper to rebuild simply because it is a more popular engine choice and the prices of rotating parts are cheaper.
Just my $.02
Old Jul 18, 2002 | 01:14 PM
RAW ROC-Z's Avatar
i would go with a 350.....but i jus rebuilt my 305 and im pushin around 325 horses..not bad for a paperweght or a lawnornament
Old Jul 18, 2002 | 02:18 PM
kvu's Avatar
kvu
look at my response in this post https://www.thirdgen.org/techbb2/sho...hreadid=118963
InfinityShade
Feb 21, 2016 01:29 PM
fbirdroller
Sep 2, 2015 10:27 PM
someone972
Aug 30, 2015 12:52 AM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
