305tpi into a 350???
Old Jul 18, 2002 | 01:03 AM
88formla350's Avatar
Will a tpi from a 305 work on a 350? Thanks
Old Jul 18, 2002 | 01:18 AM
TunedPortZ's Avatar
yes, you will probably need some bigger injectors though, besides that it will work perfectly without any modification. :lala:
Old Jul 18, 2002 | 06:07 AM
packerfan's Avatar
I' doing the same swap,using a "79 350 truck engine. Was wondering witch heads to use. Are the heads similar in cc size?
Old Jul 18, 2002 | 06:17 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
It's easy, you'll have to change the knock sensor too
No, it absolutely cannot be done under any circumstances. No one has ever attempted it before and been successful. Many have tried, and all have failed, failed miserably. Usually at the expense of family and friends. I defy you to try it!
Old Jul 18, 2002 | 10:21 AM
tpi_roc's Avatar
:lala:
Old Jul 18, 2002 | 01:39 PM
Im confused everybody tells me it will work fine, but TPI GUY is saying it is suicide. Does anybody know for sure? Has anybody done it succsessfuly? Thanks
Old Jul 18, 2002 | 02:09 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
I fully support the decision to get rid of any 305
No, it's easy. Use the search button in the upper right hand corner and you'll see the question comes up every week.
You'll need new injectors, a new knock sensor, and to do it right, look into PROM burning. Not too difficult.
Old Jul 18, 2002 | 09:29 PM
Actually im not getting rid of a 305...I allready have a 350TBI I am just taking the 305s TPI setup off and putting it on my 350. How much are the injectors and sensor? I tried searching to find more of this topic, but it would only search for 1 keyword. How do I do the switch? Thanks
TX-SleeperC5
Feb 24, 2016 01:34 PM
89fast5oh
Sep 8, 2015 09:55 AM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
