water in engine oil
Old Jul 19, 2002 | 11:37 PM
sonnyb's Avatar
water in engine oil
i have water in my engine oil. i replaced the head and intake gaskets. all bolts were torque to specs. engine was not started, just put coolant in my radiator and coolant level started dropping so i check my oil level and water was in my oil. could there be anything else wrong beside head and intake cracks, maybe wrong gaskets and etc.
Old Jul 20, 2002 | 12:07 AM
craiger's Avatar
Did you put thead sealant on the intake bolts?
Old Jul 20, 2002 | 12:44 AM
sonnyb's Avatar
Re: water in engine oil
Old Jul 20, 2002 | 12:49 AM
sonnyb's Avatar
yes, i used arp thread sealer
Old Jul 20, 2002 | 12:54 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
did you have the heads magnafluxed? (checked for cracks) did you cut the heads? did you check your intake? it might have a crack in one of the water passages.
Old Jul 20, 2002 | 01:17 AM
sonnyb's Avatar
heads were magnafluxed pressure tested but not cut. as for the intake you might be right about a crack somewhere. does water flow through a tpi intake manifold?
Old Jul 20, 2002 | 08:43 AM
Car: 1988 IROC-Z
does thermostat ring a bell? water does in fact pass through through the front of every SBC intake. another possiblilty could be that the intake is warped just enough for it not to seal properly. as for the heads.......you always have them cut unless warpage was within tolerences. i'm trying to be optimistic here. the last thing if it isn't one of these would be your block.
Old Jul 20, 2002 | 10:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I agree with the above but aren't you also supposed to retorque after the car's been warmed up at least once?
Old Jul 20, 2002 | 10:48 AM
Car: 1988 IROC-Z
he didn't even start the car.
Old Jul 20, 2002 | 11:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I'm still working on my second cup of coffee.
Old Jul 20, 2002 | 11:36 AM
sonnyb's Avatar
hey guys thanks a lots for the posts. one thing i fail to mention is that when i was cleaning the old gasket from the intake i saw some pitting in 2 areas just under the water port on the left side of the intake. could that be the reason for the leak? car has been sitting in my garage for about 3 years or more, i decided to start it one day and saw a little bit of white smoke out of tail pipes and decided to replaced the head and intake gaskets. i made sure the head and intake were torque down right.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
