Sensor on air cleaner assembly???
Old Jul 21, 2002 | 02:32 AM
91TealRS's Avatar
I bought an 86 IROC LB9 a few weeks ago which was missing the air cleaner assembly. I went to a junkyard and got one. When I got back to put it on, I realized there was a probe on it towards the rear of it on the drivers side. I'm guessing some kind of temp sensor. Point is...it obviously doesn't connect anywhere to the car! Was the air cleaner off a V6 or something that had a sensor there?
Old Jul 21, 2002 | 03:42 AM
Morley's Avatar
Sounds like that car had the temp sensor relocated to the ducting, ignore it, it won't do you much good in a MAF car. Some company makes temp sensor relocation kit but the SD cars are the only ones that really benefit from it.
Old Jul 21, 2002 | 08:22 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
all of the v6 ones are like that.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
92purpz28
Aug 11, 2015 02:30 PM
