Starter will not engage (88 GTA)
Old Jul 24, 2002 | 04:30 PM
Chet's Avatar
Car: GTA
When I turn the key to start I get nothing from the starter, no noise, nothing. It's like if you tried to start a manual car without the clutch all the way in. There are no codes, and I checked the starter and it is still good, there just isn't any power going to it. I don't think it's the VATS becuase the security light goes out, I believe the light will stay on if there is a problem. Any ideas where I should start next...if anyone has a complete wiring diagram I might need it.
Old Jul 24, 2002 | 06:12 PM
IROCZ88's Avatar
That happened to me and it was the ignition switch. I pulled one out of a junkyard car.
It is also possible that the starter has completely took a ****. Solution=Buy a new starter.
Also, Check the connections to the starter. You never know.
Old Jul 25, 2002 | 04:57 AM
madmanups's Avatar
Once that happend, I towed my car from the wrong place and fu**ed up my hood latch, turned out all i had to do was touch a loose wire to the starter. I baught a new starter for no reason as well. Good thing the old one really was broken too, the selanoid was bad.
Old Jul 25, 2002 | 10:59 AM
Chet's Avatar
Car: GTA
ignition switch and starter are both good, I still stumped
Old Jul 25, 2002 | 12:13 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
The other possibility is that the neutral safety switch is bad...the one that won't let you crank until you are in park or neutral...
I would check that out and bypass that switch to see it is the problem..
HTH,
Old Jul 25, 2002 | 03:53 PM
IROCZ88's Avatar
How do you know they're both good? You obviously can't turn the motor over to check.
Old Jul 26, 2002 | 08:06 PM
Chet's Avatar
Car: GTA
IROCZ88, I know they're both good because I just replaced them a year ago. But I did find out what was wrong. There are two yellow wires in the ign. tumbler that are part of the VATS, and one of those wires was clipped off. It's one of the worst designs I've ever seen.....two stationary wires connected to a moving part
TX-SleeperC5
Feb 24, 2016 01:34 PM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
Formula_88AE
Sep 3, 2015 01:47 PM
