Vats Removal on 305TPI
Old Jul 27, 2002 | 12:26 PM
maverick544's Avatar
I have a 89 Formula with a 305TPI engine in it. Now every once in a while I goto start the car and when I turn the key all the way as usual to start the car the dummy lights come on but nothing else happens. I than have to take out the key and wait usually 4minutes till the car will start. My mechanic told me its the Security system by GM which I know it is VATS. I heard you can get a burned chip or someting to run the car without the VATS system engaged. If so I will be willing to pay anybody willing to make me a chip. But for now just give me a little advice guys. PS:THis same problem occurs in my 89 V6 Firebird too.
Old Jul 27, 2002 | 12:32 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
VATS sends a signal to both the ECM and a relay that disables the starter.
To get rids of VATS you not only need a PROM with VATS disabled, you will also need to permanently enable the starter relay. I don't know where it is located off teh top of my head but you should have no prblem finding the info with a few searches.
Old Jul 27, 2002 | 12:42 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Its in the drivers side kick panel.
-- Joe
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
studebaker60
Sep 7, 2015 12:36 PM
