305 for 350 engine swap in my IROC
Old Aug 5, 2002 | 01:54 AM
86YellowIROC's Avatar
Like the guy said a few posts ago I know ya'll are tired of TPI swap questions but this is more of an Engine swap question. I have an 86 IROC with the 305 TPI and want to swap in a 79 350 that has been bored .030 over and has a 204/214 cam in it and 883 1.94 1.5 76cc chamber heads. I do believe I need to put bigger injectors on the TPI to feed the 350..but can I use the same ECM or will I need to burn a new chip? Will this work or is it all a pipe dream? Any help would be greatly appreciated.
Old Aug 5, 2002 | 03:36 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Sounds like it will work to me. I belive you will need a different flexplate to hook it up to the tranny. Just burn a chip and the comp. will work fine.
might need a second opinion though. I'm not an expert on engine swaps. Try doing a search and see what you can find.
Old Aug 5, 2002 | 10:07 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll need a new flywheel.
Old Aug 5, 2002 | 12:47 PM
I have the Flywheel that came with 79 350 will it work?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
