what kind of hp could you squeeze out of a 305tpi?
Old Aug 8, 2002 | 10:42 AM
smoove2022's Avatar
Just wondering what kind of power these engines are capable of if every bolt on in the book was installed while retaining the stock displacement and internals (pistons, rods, crank), both N/A and with forced induction. I know it would not make the power of a 350 but I don't have the resources to do an engine swap.
Thanks!
Old Aug 8, 2002 | 11:50 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You could get into the 12s NA on a stock LB9 bottom end with decent heads, cam and tuning
Slap a blower on a similar combo and run way into the 11s depending on how badly you're trying to plant rods in the road.
Did you have a more specific question or was that it?
Old Aug 8, 2002 | 11:51 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can squeeze as much as you want out of a 305, but you're going to suqeeze your wallet twice as hard.
Old Aug 8, 2002 | 12:44 PM
smoove2022's Avatar
Well I think I'd be squeezing my wallet just as hard with a 350 if not harder. At least if I keept my 305 I'm saving myself money and headaches from buying and swapping engines... And I'll get a little better mileage from having a slightly smaller engine.
Old Aug 8, 2002 | 03:02 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Not a single bit of that makes sense.
A 350 swap is NOT hard and NOT expensive!
You can pull the 305 and bolt up EVERYTHING to the 350.
A little tuning and you've got a daily driver until you start buying aftermarket parts and mods for it.
I did my 305 to 350 swap in just over a day with a friend helping.
Why do threads like this keep popping up?
Old Aug 8, 2002 | 04:24 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
i would suggest swapping in a 350, but if you stay with the 305, you can make it as fast as you can afford. a complete l98 was swapped under my exsisting tpi for well under 2000.
Old Aug 8, 2002 | 04:54 PM
tpi_roc's Avatar
The guy has 16 posts, lets not all start clobber'n him on the 305 thing
Depending on what you're classifying as a "bolt on" you can probably make it to 13's or 12's, if to you heads are bolt ons. If you mean like "home made ram air" and "Relocated IAT" etc... fowgetaboutit.
Old Aug 8, 2002 | 06:57 PM
smoove2022's Avatar
What don't you understand Chubby? I posted very clearly in my origional thread that I DON'T have the resources to do an engine swap. Not everyone has a cherry picker in their garage! Or friends to help them! Man... someone needs a nap.
I thought this was a tech forum not a bragging contest! WOW you can swap an engine in a whole day! Lets see I must have a trophy for you somewheres...:nono: Oh yea there it is!
Old Aug 8, 2002 | 07:01 PM
tpi_roc's Avatar
Welcome aboard
and you'll need to get used to chubby this is just how he is.
And with that being said I think we got your how much power can a 305 get question answered, to restate it. "The only thing that replaces cubic inches is cubic money".
Now that the tech has ended and flames have begun I think this ones over
Gunner242
Dec 25, 2015 04:49 PM
hartsmike
Oct 2, 2015 07:11 AM
the_hamturdler
Sep 30, 2015 12:50 PM
Stryker412
Sep 20, 2015 06:59 PM
