Will I need a vacuum canister with this cam???
Old Aug 13, 2002 | 10:45 AM
CamaroX84's Avatar
Here is the setup I will be running as soon as AFR finishes my heads (which have taken two months now, by the way):
-Stealth Ram Intake
-AFR 195cc heads milled to 64cc chambers
-Comp XR282HR-10 Cam: 230/236 dur at .050, .510/.520 lift, 110 deg lobe sep
I was wondering if I will need a vacuum canister for my power brakes to work properly. Thanks in advance.
Old Aug 13, 2002 | 01:26 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You brakes will be fine but keep the stock canister so your HVAC still works.
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
