how long can a tpi feed a 383
do any of yall know how long a fully non stock tpi setup could keep enough air into a 383? im talkin the tpi havin as&m runners, lpe or some other place porting the plenum, super ram base, and as&m 58mm throttle body. my 383 is finaly coming together and im getin to were i need to make a choice on the intake. i want it to look stock b/c im telling everybody that when my car goes into the shop that im just gettin the motor rebuilt and i want it to look mostly the same. if i put another intake setup on there then anyone would be able to tell the the diffrence. if it cant be done then alright but should i do all of that or just buy a stealth ram and save alot of money? the motor is going to fast it has fast burn heads and a custom cam and the intake is the only thing i have left to decide on so give me some of yalls expert advice
Car: Death Mobile
Engine: 666 c.i.
Nope, read the post below regarding the "Translator". Basically, the only thing you can do with MAF is compensate within the eprom by adding extra fuel when in PE Mode.
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
I'v heard it (MAF) will still be good, just in upper RPM's it will max out and you'll loose a little bit, but not much.
If its a daily driver I wouldnt worry about it.
as for the intake feeding it.... it should, I mean you'll still run out of breath in Upper RPM's due to the intake, but not as bad as a stock TPI. Just add extra fuel with a chip and have fun.
thats what i thought. anyway does anyone know how long it will make power for befor it dies out. i dont want to stop this motor from beeing able to make power up high so just how long will the intake be able to keep up. dont mind the maf for now im workin on that
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Originally posted by Gausy
Oh yeah, they are drilled for old or new style valve covers however.
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
