which roller rockers are best???
Old Aug 21, 2002 | 01:58 PM
90Iroc-Zee's Avatar
okay jegs has a set of aluminum RR 1.6 3/8 (what size do i need??? 3/8 or 7/16?) for 199.99 and crane has Energizer aluminum ones for 189.99. just wondering what size it is whether 3/8 or 7/16 and which brand has given the least amount of problems with the most gains. input appreciated...hope to get another 10hp outta this!!!
Old Aug 21, 2002 | 03:15 PM
PonchoDoc's Avatar
Re: which roller rockers are best???
Ok you did mention input appreciated. 10hp(out of what I am assuming is a 305) is excessive for just roller rockers and for the $250 or so it will end up costing you seems like your better off gathering a bit more cash and waiting for a set of aluminum L98 heads.
Old Aug 21, 2002 | 03:17 PM
tpi_roc's Avatar
I dont see any reason he can't gain 10hp from increasing lift (if he went 1.6) and reducing friction, not to mention the closer tollerances from rocker to rocker.
Old Aug 21, 2002 | 11:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
For your application you only have a few options because you need self aligning ones and narrow body rockers.
A. Comp Roller TIP Not Full Rollers .Self Aligning 1418-16 $191.95
B. Crane Gold Race Rockers. Self Aligning ,Narrow Body 10759-16 $299.95
C. Comp Cams also sells the Pro Magnums for SA and Narrow body for about$260.00
Old Aug 22, 2002 | 06:58 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd bet he could get 10hp from a set of 1.5 rockers. The stock rockers are notorious for flex. One of the magazines just built a 350 test mule (with 461 heads - just like mine!) and they tested a few sets of rockers. They tested the stock rockers, a set of aftermarket 1.5s, and a set of 1.6. They found a pretty sizable gain just from installing the aftermarket 1.5s.
Old Aug 22, 2002 | 08:22 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Go with the Crane Gold self aligning rockers. They are about as good as you can get for your application.
Old Aug 22, 2002 | 09:55 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I'll be using the LT4 roller rockers in my 350. I'll let ya know how it goes when it gets running.
www.sdpc2000.com has them for about 270 dollars and they come with the lock nuts also.
Kat
Old Aug 22, 2002 | 10:01 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Aren't the GMPP roller rockers nothing but Crane Golds with a blue anodized finish rather than gold?
Old Aug 22, 2002 | 10:34 AM
90Iroc-Zee's Avatar
Yea the gold ones dont seem different, i need self aligning, but you guys never answered whether its 3/8 or 7/16.
is there an equation to figure out how much more lift i would get??? i got the L98 cam
Old Aug 22, 2002 | 11:01 AM
tpi_roc's Avatar
Camlift X 1.6 = lift
Or if you have valve lift at 1.5 then
lift / 3 X 2 x 1.6
Example:
.500 lift @ 1.5 ratio
Divided by 3 = .16666666666666666
Multiplied by 2 = .3333333333333333
Multiplied by 1.6 = .533 lift @ 1.6:1 rocker arm ratio
Old Aug 22, 2002 | 11:03 AM
tpi_roc's Avatar
By the way im sure theres an easier way im over looking
But hey, my way works
Old Aug 22, 2002 | 11:10 AM
Mark305TBI's Avatar
I came up with the same answer as you, but I go about it a bit differently (unless I just didn't follow your method...).
1. (Gross lift with 1.5 rocker) / 1.5 = cam lift.
2. (cam lift) * 1.6 = Gross lift with 1.6 rocker.
Old Aug 22, 2002 | 11:12 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Stock & most aftermarket heads have 3/8" studs, however they can be changed fairly easily, if they are the threaded in type. Stock pressed in type are 3/8".
Old Aug 22, 2002 | 01:23 PM
PonchoDoc's Avatar
Which magazine? And how sizable hp gains from the stock to the 1.5's? My theory is that on a 305 that 10hp is way too much to expect, I am sure that changing the lift on the cam can increase hp, and in relation to possibly a better ratio as most stock ratios are ususally under 1.5 as well. I just think for the amount of money being discussed here $300 for the rockers alone that this is the wrong way to go. For around $500 a decent used set of aluminum L98 heads can be had w/ roller tip rockers(aftermarket). And a set of L98 heads will be making more than just 10hp+. I have seen articles describing this setup and it seems ideal way to go for a 305.
Old Aug 22, 2002 | 01:41 PM
Mark305TBI's Avatar
Another way to do it would just be to multiply the lift with the 1.5 rocker by 1.066667 (it's really just 1.0sixes all the way to infinity).
Ex. .500" x 1.066667 = .533"
Old Aug 22, 2002 | 09:24 PM
iroc22's Avatar
That's what I have heard too.
Old Aug 22, 2002 | 10:29 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Actually the GMPP 1.6 rockers are just brushed aluminum (silver).
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
