i blew my engine, need advice on what to do next
Old Aug 27, 2002 | 11:02 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i have a 92 z28 with the 305 and i recently threw a rod. the mechanic said he can fix it for 2 grand, but i'm not paying that kind of money to end up with the same thing. so i was thinking about going to the junkyard and buying a 350 from a truck or something and then buy a rebuild kit and a cam and put it all in. should i just go with that? please help, thanks.
Old Aug 27, 2002 | 11:47 PM
89Irocz23's Avatar
Yeah Id either go that route or buy a crate motor. You could get the 350 HO with 330 hp and 380 IBS torque. You would need a intake for vortec heads though, but you mys well do that anyway. Get the highflow base for it. I believe the 350 HP is in the 2200 range which is pretty good for that much power.
Old Aug 27, 2002 | 11:48 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
If you're gonna do all that, I would just look for a 350 block, that way you won't have the trouble of tearing down the motor. It'll save the gabarge men quite a few pounds when throwing the old parts out. The engine kit sounds good and with a good size cam like the LT4 hot cam, you should be on your way.
theshackle
Mar 5, 2017 06:37 PM
IroczFan
Oct 6, 2015 10:13 AM
masonta
Aug 31, 2015 10:14 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
