Rough idle - real bad on startup
Old Sep 9, 2002 | 02:15 PM
Eric's Avatar
Car: 87 GTA
When the car is totally cold, it starts after one or two cranks (good) and revs up to 1500rpm or so (good), then immediately drops to 500rpm or less and almost dies. It runs there for a few seconds, then revs back up to about 800rpm and there it sits.
It idles pretty rough, even after it is warmed up. It also has a bad hesitation off idle. It has new plugs and wires, and the cap and rotor are not very old (Accel). I searched for a vacuum leak but can't find anything obvious (don't have a vacuum gauge). There are no codes. Any ideas?
Old Sep 9, 2002 | 06:09 PM
tpi_roc's Avatar
EGR valve stuck open?
Any vacuum leaks (less likely if it idles too low)
Is your check engine light on?
Old Sep 10, 2002 | 11:06 AM
Eric's Avatar
Car: 87 GTA
Don't think I have any vacuum leaks. I was also suspecting the EGR - how do you test it? It's awfully hard to get at under the plenum, so I would like to avoid pulling it unless I am going to replace the EGR.
No codes. No SES light.
Old Sep 10, 2002 | 11:12 AM
tpi_roc's Avatar
You can use a vacuum to try to open/close the EGR valve
Old Sep 10, 2002 | 11:30 AM
Eric's Avatar
Car: 87 GTA
Hmmm..... So how would I know if it is opening/closing? Could I just suck on the vacuum line to make it go? Pretty hard to hook up a vaccum to a little hose.
Old Sep 10, 2002 | 11:33 AM
tpi_roc's Avatar
Yea if you suspect its the EGR the bottom line is you're probably going to need access to it to investigate. If you determin it bad you can then replace it, if it works then you know its obviously something else. There have been many posts on EGR testing with a vaccum, unfortunatly I dont have the details since my car has nothign it doesn't need, and it certainly didn't need egr
Old Mar 3, 2003 | 10:20 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
suject
Hey TPI_ROC, how do you get rid of the EGR system? Do you have any more detailed info as I'd like to deep-6 mine as well.
Old Mar 3, 2003 | 10:22 PM
tpi_roc's Avatar
A blockoff plate and a burnt prom
Old Mar 4, 2003 | 03:46 AM
burroughs's Avatar
Car: NONE! and it SUCKS!
maybe a flywheel problem??
Old Mar 4, 2003 | 03:14 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Where do I get a blockoff plate?
Old Mar 4, 2003 | 03:16 PM
tpi_roc's Avatar
Make one
Old Mar 4, 2003 | 04:10 PM
BOTTLEDZ28's Avatar
Transmission: A4
TPIS sells block off plates but your gonna get a SES light if you dont remove the EGR from the chip like stated above. The cost of a new chip is over$100
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
