Retro Fit ?
Old Sep 12, 2002 | 03:26 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Retro Fit ?
Well I spun a rod bearing the other day and my friend is selling his 383 short block which is a 4 bolt main and 2piece rear seal block. So if I buy this block can I stick my OE style cam in there and if so what modifications will be needed. I know I will need aftermarket lifters already.
Old Sep 13, 2002 | 01:22 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
anybody?
Old Sep 13, 2002 | 07:18 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Yes, you can run a late model "step nose" cam in an early block by using a late model timing chain and a spacer kit. The timing chain is available anywhere. The spacer kit is available through Lingenfelter Performance 219/724-2552.
Best move I made was to step up to a 383!
www.geocities.com/dzperf
Old Sep 13, 2002 | 07:35 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i mite be cheaper to just get a new cam and lifter set.
Old Sep 13, 2002 | 09:08 AM
92superram's Avatar
I'm not all that sure, but if the block is not made for a rollercam, you will have to get a retrofit kit to keep the roller.
Old Sep 13, 2002 | 11:23 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Retrofit refers to the roller lifters. Nothing needs to be done to the block.
Old Sep 13, 2002 | 06:12 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
and a cam button. seeing as there is no provision for a cam retainer plate.
Old Sep 15, 2002 | 02:01 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
So I need a cam button, aftermarket roller lifters, and a spacer for a roller timing chain right?
Old Sep 15, 2002 | 09:43 AM
rhuarc30's Avatar
Yep, but your leaving a lot of performance on the table to swap the stock l98 cam in there. I'd look at upgrading while you were at it.
Old Sep 16, 2002 | 01:13 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
The cam I have is in the sig.
Old Sep 17, 2002 | 01:07 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Or simply keep the roller cam out and buy a regular old flat tappet cam...like I did for my 406...
Nothing wrong with that and for all the positives about a roller cam, it is still expensive and a PITA to use in an older block...That is my opinion about it, and it won't change....
Comp and Crane both have some flat tappet cams that are close to the specs of your current cam, but not exactly as much duration.
Look around and you should be able to find what you want for a reasonable price.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
