Where can I find TPS mounting screws?
Old Sep 15, 2002 | 03:06 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Anyone have an idea where to get some more TPS mounting screws?
The dealer wants $21 for them! Checked several hardware stores and can't find a screw with the same threads, 10-32 is close but not quite it. I'd prefer the ones with a hex slotted top so I don't strip the torx head again.
Old Sep 15, 2002 | 08:12 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
The TPS mounting screws are 4.5mm x .75mm pitch. These shoud be easy to find at a fastener supply house. They should have several different styles of screws available.
Old Sep 15, 2002 | 09:10 PM
2QUIK6's Avatar
Thanks for the size info alloy. Its probably the only screw on the car thats metric thread!
Old Sep 17, 2002 | 03:41 AM
93ND500's Avatar
...never had any luck locating those odd ball screws. Nobody had the right size...Grainger, Mc Master, Fastenal, Neill Lavielle, nobody. The only place that could get them was the dealership. I got tired of looking anymore so I drilled and tapped them out to the closest standard thread. I believe it was 10-32....been a while since I did it.
Old Sep 17, 2002 | 08:37 AM
2QUIK6's Avatar
There's a few junkyards a few miles down the highway, guess I'll go make the rounds down there looking for a few spares.
Old Sep 17, 2002 | 11:31 AM
Morley's Avatar
Boy, are you in for a surprise.
Of note, the stock TPS screws are made of alumnium and strip very easily.
Old Sep 17, 2002 | 11:54 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
$21 is list price for a fastener kit which includes the TPS screws, washers & ID plate screws. Try here: http://www.gmpartsdirect.com
the part# is 17110848
Old Sep 17, 2002 | 01:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Aubichon Hardware should have plenty. Mine did. Other hardware stores should be well stocked too. If all else fails, try fastenal.com.
mdtoren
Aug 23, 2015 12:52 PM
Wife'sCar
Aug 22, 2015 01:46 PM
mdtoren
Aug 16, 2015 05:45 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
