Vacuum in my tank - why?!
Old Sep 13, 2002 | 05:03 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Hi guys,
does anybody have any idea why there occurs vacum in my gas tank (TPI, '89gta)? Every time I take off fuel cap after the ride there's sound of sucked air. I wonder how it effects on fuel pressure...
Thx in adv.
Mike
Old Sep 13, 2002 | 05:55 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
do you have a vented gas cap? if you do, then it may be clogged. get a new one.
Old Sep 13, 2002 | 06:08 PM
turtle's Avatar
i doubt it is a sucking noise but a pressure release noise, the tank ends up pressurized as you drive around. the charcoal canister has a check valve that controls the tank pressure and sends excess pressure and vapors to the engine to be burned.
Old Sep 13, 2002 | 10:58 PM
88TAJeff's Avatar
Car: 88 T/A
Mine does the same thing- does this mean the charcoal canister isn't working properly? how would I test it?
Old Sep 14, 2002 | 02:21 AM
z_power's Avatar
Car: '89 GTA
This is sound of air flowing into tank, fillin' empty space after certain volume of fuel has been pumped out. Also I can hear sound of tank walls shootin' when there's been lot of fuel burned since prev. cap releasing
Old Sep 14, 2002 | 07:58 AM
turtle's Avatar
if your sure its the tank sucking in air check the valve right in front of the charcoal canister. the tank should end up pressurized to a point that is normal. put sucking sounds like the line/valve maybe reversed, so instead of building pressure and releasing it is drawing down a vacuum.
theres nothing wrong with the pressure release sound when you pop the cap off and i doubt that vacuum is doing any real harm either, but if the system is working right you will get the best gas mileage.
oh the emptier the tank is the louder it will be, normal.
Old Sep 14, 2002 | 12:43 PM
z_power's Avatar
Car: '89 GTA
OK, I'll check the valve tommorow. Thanks
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Bohemian
Aug 15, 2017 05:11 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
kx3g
Sep 28, 2015 08:14 AM
